Wanted: 2-33 left wing
Old March 20th 06, 09:48 AM posted to rec.aviation.soaring
Default Wanted: 2-33 left wing
Eric Greenwell wrote:
Can I redeem my drab desert by wondering why "mild hail damage" was the
perfect condition? Do you suppose the right wing already has "mild hail
damage", and so a left wing with matching damage is required?
Hmmm golf balls fly futher with dimples, is 2-33 with 50:1 possible?
paul
Old March 20th 06, 03:03 PM posted to rec.aviation.soaring
Shhhhhhhh. Super secret Super-Schweizer project.
MM
Old March 20th 06, 07:52 PM posted to rec.aviation.soaring
With that riveted wing, I suspect you'd have to bolt on a JATO unit to
give a 2-33 50:1 performance.
Johan Larson
Old March 22nd 06, 02:26 PM posted to rec.aviation.soaring
If you installed two left wings, or two right wings, but installed the
"wrong one" facing backwards, it might be perfect for thermaling in a tight
column of air - as long as you made sure you always went in the correct
direction.
It could also be good for flat spin recovery - if you made sure you spun it
in the correct direction.
Tow rope attachment might be somewhere on the rear facing wing, to help it
launch straight, althugh it might require some experimentation.
Colin
Old March 22nd 06, 03:09 PM posted to rec.aviation.soaring
direction.
That sounds like a long-discarded prototype for the helicopter, before
they discovered you don't want the crew pod to spin with the blades.
Just wind the tow rope around a vertical axis, like winding the string
around a top. Then pull hard, and the device will take off on its own.
Good idea, Colin.
Johan Larson
Old March 22nd 06, 03:25 PM posted to rec.aviation.soaring
Boy, that is a great idea. Just hang the cockpit below the fuselage, on a
swivel, and the pilot can keep facing one direction during a tight thermal.
My wife will finally get relief from those tight turns she does not like.
And pilots will no longer be uncomfortable in flat spins or graveyard
spirals.
Colin
Long wing twisting JJ Sinclair Soaring 13 June 28th 05 06:42 PM
Canard planes swept wing outer VG's? Paul Lee Home Built 8 January 4th 04 08:10 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
