Prop position
Old March 20th 06, 01:26 PM posted to rec.aviation.owning,rec.aviation.piloting
Default Prop position
I'm talking about where the prop stops when I shut down the engine. What
would cause a 2-blade, constant speed prop on a Lyc. O-360 to suddenly begin
stopping in a different position than it had every time for the last 3
years?
My prop has always stopped parallel to the pavement until last night, when
it stopped at 10:30/4:30 position. I pulled it through two complete
revolutions and compressions felt ok.
Dan
C172RG at BFM
Old March 20th 06, 01:51 PM posted to rec.aviation.owning,rec.aviation.piloting
On Mon, 20 Mar 2006 07:26:24 -0600, "Dan Luke"
years?
If I have the engine idle-ing less at or less than 1000RPM, the prop
on the Lyc O-360-A4A on my PA28-180 stops in the same position 95% of
the time.
If the RPM is higher than 1000 (before killing the mixture), it
(frequently) stops at a different position.
Old March 20th 06, 03:41 PM posted to rec.aviation.owning,rec.aviation.piloting
Get a compression test. Seriously. One of your cylinders (the one that
it stops on) very well may have low compression. Something has changed.
I'd check it out.
Old March 20th 06, 04:01 PM posted to rec.aviation.owning,rec.aviation.piloting
I'd check it out.
That's what I thought at first, but how come it stops in the new place no
matter whch cylinder is coming up on compression? And if a cylinder is
really going, how come I can feel compression on each cylinder as I swing
the prop?
I've had soft cylinders before that caused the prop to stop in an unusual
position; this doesn't seem the same.
Dan
C172RG at BFM
Old March 20th 06, 04:04 PM posted to rec.aviation.owning,rec.aviation.piloting
My suggestion - Could just be lower internal friction due to oil
viscosity, or even the engine simply breaking in. I'd almost be more
concerned about why it always stopped horizontally, as at least most
broken-in 4 cylinder engines stop with the prop at 45 degrees (10:30).
First verify that the mags actually do indeed shut off, then kill the
engine with the mixture, and do a hand prop to see if all cylinders
feel the same. Only if there is a noticeable difference, get a
compression check.
Old March 20th 06, 04:19 PM posted to rec.aviation.owning,rec.aviation.piloting
The engine is well broken in. 300+ hrs. since a top overhaul.
I'd almost be more
Really? This seems to vary among the O-320 and O-360 engined aircraft I see
on the ramp. I'll do a more careful survey next time I'm out there.
compression check.
Did that. They feel the same.
Dan
C172RG at BFM
Old March 20th 06, 05:14 PM posted to rec.aviation.owning,rec.aviation.piloting
Well the only way to find out is to get a compression test. I don't
know the answer to your delimna, and neither do you. "By hand"
compression tests are not worth much. Do it with a guage.
The only other answer is some airplane elf came and reindexed your prop
in the middle of the night :-)
Old March 20th 06, 06:14 PM posted to rec.aviation.owning,rec.aviation.piloting
"Doug" wrote in message
I was afraid that was the answer. It's *got* to be a cylinder or two,
doesn't it?
Old March 20th 06, 06:20 PM posted to rec.aviation.owning,rec.aviation.piloting
More thoughts -
Your prop just might be indexed correctly but differently than the ones
I'm recalling. That seems to be a snake oil thing with different
aircraft.
Another lo-cost check would be to do an oil analysis on a sample. I
know of an engine that would get really stiff when warm that had a bad
cam lobe & misc bearing contamination. It would free up on cooldown.
I contend the equal cylinder-feel-on-hand-prop test is an effective way
to check out the upper end of an engine, although it would not uncover
any lower end mayhem. An oil analysis is the cheapest way to check or
track the lower end. Be sure to take the sample correctly though.
Old March 20th 06, 06:54 PM posted to rec.aviation.owning,rec.aviation.piloting
I once prop-positioned a cutie on the ramp... If you must know, I
crashed and burned... :-(
GPS and old-fashioned thinking? G Farris Instrument Flight Rules 92 December 22nd 05 05:39 PM
3 blade prop position on 6cyl engine. Paul Lee Home Built 3 February 26th 04 12:47 AM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
