Prop position
Old March 20th 06, 04:19 PM posted to rec.aviation.owning,rec.aviation.piloting
Default Prop position
"nrp" wrote:
My suggestion - Could just be lower internal friction due to oil
viscosity, or even the engine simply breaking in.
The engine is well broken in. 300+ hrs. since a top overhaul.
I'd almost be more
concerned about why it always stopped horizontally, as at least most
broken-in 4 cylinder engines stop with the prop at 45 degrees (10:30).
Really? This seems to vary among the O-320 and O-360 engined aircraft I see
on the ramp. I'll do a more careful survey next time I'm out there.
First verify that the mags actually do indeed shut off, then kill the
engine with the mixture, and do a hand prop to see if all cylinders
feel the same. Only if there is a noticeable difference, get a
compression check.
Did that. They feel the same.
Dan
C172RG at BFM
Old March 20th 06, 06:20 PM posted to rec.aviation.owning,rec.aviation.piloting
More thoughts -
Your prop just might be indexed correctly but differently than the ones
I'm recalling. That seems to be a snake oil thing with different
aircraft.
Another lo-cost check would be to do an oil analysis on a sample. I
know of an engine that would get really stiff when warm that had a bad
cam lobe & misc bearing contamination. It would free up on cooldown.
I contend the equal cylinder-feel-on-hand-prop test is an effective way
to check out the upper end of an engine, although it would not uncover
any lower end mayhem. An oil analysis is the cheapest way to check or
track the lower end. Be sure to take the sample correctly though.
Old March 20th 06, 07:57 PM posted to rec.aviation.owning,rec.aviation.piloting
In rec.aviation.owning nrp wrote:
: Your prop just might be indexed correctly but differently than the ones
: I'm recalling. That seems to be a snake oil thing with different
: aircraft.
There was a thread on this awhile back. I'd concluded that at least on the PA28
like mine, the discrepancy is in the service manual itself. It calls for 10-2 IIRC, but
doesn't say if it's as viewed from the front or the rear. So, 50% of them out there are on
one way, and the others are 60 degrees off. I *still* don't know which is right.
-Cory
* Cory Papenfuss *
* Electrical Engineering candidate Ph.D. graduate student *
GPS and old-fashioned thinking? G Farris Instrument Flight Rules 92 December 22nd 05 05:39 PM
3 blade prop position on 6cyl engine. Paul Lee Home Built 3 February 26th 04 12:47 AM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
