Dave Butler wrote:
Dave Stadt wrote: "Dave Butler" wrote in message news:1143124006.95524@sj-nntpcache-5... Dylan Smith wrote: On 2006-03-23, Morgans wrote: Flutter scares the crap out of me. I would strongly doubt (based on what I know) that there was even the remotest chance of flutter. From what I understand, flutter would require the flexing of the wing structure in such a way to cause the whole thing to oscillate. This happens with experimental airframes (or used to happen) because the whole surface or wing would warp under aerodynamic loads in such a way that you'd get the oscillation. A dent in a Mooney aileron isn't going to cause that. FWIW, Mooney ailerons are required to be rebalanced after they are *painted*. As are almost all flight control surfaces on most all aircraft. OK, I thought this requirement came from manufacturers service letters and the like. I know about Bonanza and Mooney. Is there some other more general requirement? Here's a quote from http://www.avweb.com/news/maint/182829-1.html "Getting Good Paint" by Paul Bertorelli: "Guenther and better shops insist—rightly—that controls be removed, stripped, inspected and, most important, rebalanced after painting. On some controls—Bonanza ruddervators and Mooney ailerons—this is a critical task and shouldn’t be skipped. But it should still be standard on all aircraft. Guenther goes so far as to record the balance data in the aircraft logbook, along with the signoff for the paint itself." which makes me think this is not a general requirement or practice. |
Flutter is determined by the torsional stiffness (and mass) of the wing
section. In this case, that did not seem to be compromised - i. e. there were no diagonal wrinkles across the wing panel. If there were diagonal wrinkles, flutter would be a real possibility. But dropping the airspeed greatly helps the flutter margin, just as increasing the max speed quickly reduces the flutter margin. I understand that during each new aircraft's flight at the factory, the test pilot must dive it to 110% of the indicated red line speed. The survivors are certfied. There were diagonal wrinkles across the aileron panel, but I don't think the aileron in itself can flutter. The question in this case would be the aileron control integrity. Someone earlier suggested blocking or locking one aileron. That could have all sorts of interesting changes and very definitely I would not recommend. |
Flutter is caused by imbalanced movable surfaces. When the
plane moves the moment arm of the surface causes deflection of the surface. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "nrp" wrote in message oups.com... | Flutter is determined by the torsional stiffness (and mass) of the wing | section. In this case, that did not seem to be compromised - i. e. | there were no diagonal wrinkles across the wing panel. If there were | diagonal wrinkles, flutter would be a real possibility. But dropping | the airspeed greatly helps the flutter margin, just as increasing the | max speed quickly reduces the flutter margin. I understand that during | each new aircraft's flight at the factory, the test pilot must dive it | to 110% of the indicated red line speed. The survivors are certfied. | | There were diagonal wrinkles across the aileron panel, but I don't | think the aileron in itself can flutter. The question in this case | would be the aileron control integrity. Someone earlier suggested | blocking or locking one aileron. That could have all sorts of | interesting changes and very definitely I would not recommend. | |
But I understand flutter also relies on the original torsional
stiffness of the wing being preserved. That if it is not (i. e. a wrinkled wing skin) the flutter margin is reduced. Might even a properly balanced control surface still flutter if the primary wing stiffness is compromised? or is the control surface CG the only determining item? THX |
Wing stiffness has more to do with control reversal, flutter
has to do with harmonics and balance. If I had a question about a control surface and I had to fly the airplane, I would limit speed to Va so that even a full deflection of the control would not break the airplane. I've seen pictures of a C210 [old plane with struts] that took off from a strip near Tulsa with just a little ice on the ailerons. I got to cruise speed and crashed shortly there after, the outer wing panels looked like a Navy fighter with the wings folded. -- James H. Macklin ATP,CFI,A&P "nrp" wrote in message oups.com... | But I understand flutter also relies on the original torsional | stiffness of the wing being preserved. That if it is not (i. e. a | wrinkled wing skin) the flutter margin is reduced. Might even a | properly balanced control surface still flutter if the primary wing | stiffness is compromised? or is the control surface CG the only | determining item? THX | |
In article .com,
"nrp" wrote: But I understand flutter also relies on the original torsional stiffness of the wing being preserved. That if it is not (i. e. a wrinkled wing skin) the flutter margin is reduced. Might even a properly balanced control surface still flutter if the primary wing stiffness is compromised? or is the control surface CG the only determining item? THX Flutter can also result from unusual airflow exciting a surface (such as the rather large dent in the aileron tip). It is a function of stiffness, true airspeed, balance and external excitations. The owner did the conservative thing -- after all his insurance company was there to stand behind him. Yes -- the whole thing was obviously a major PITA, but everyone came out fine. Congratulations! |
![]() "Dave Butler" wrote in message news:1143128184.860637@sj-nntpcache-3... Dave Butler wrote: Dave Stadt wrote: "Dave Butler" wrote in message news:1143124006.95524@sj-nntpcache-5... Dylan Smith wrote: On 2006-03-23, Morgans wrote: Flutter scares the crap out of me. I would strongly doubt (based on what I know) that there was even the remotest chance of flutter. From what I understand, flutter would require the flexing of the wing structure in such a way to cause the whole thing to oscillate. This happens with experimental airframes (or used to happen) because the whole surface or wing would warp under aerodynamic loads in such a way that you'd get the oscillation. A dent in a Mooney aileron isn't going to cause that. FWIW, Mooney ailerons are required to be rebalanced after they are *painted*. As are almost all flight control surfaces on most all aircraft. OK, I thought this requirement came from manufacturers service letters and the like. I know about Bonanza and Mooney. Is there some other more general requirement? Here's a quote from http://www.avweb.com/news/maint/182829-1.html "Getting Good Paint" by Paul Bertorelli: "Guenther and better shops insist—rightly—that controls be removed, stripped, inspected and, most important, rebalanced after painting. On some controls—Bonanza ruddervators and Mooney ailerons—this is a critical task and shouldn’t be skipped. But it should still be standard on all aircraft. Guenther goes so far as to record the balance data in the aircraft logbook, along with the signoff for the paint itself." which makes me think this is not a general requirement or practice. It is. Most all manufacturers provide control surface balance requirements. Even the Cessna 150 requires it. I also believe it is in the FARs. |
Cirrus chute deployment -- an incredible story | Michael182/G | Instrument Flight Rules | 48 | July 14th 05 03:52 PM |
My first lesson | Marco Rispoli | Aerobatics | 3 | May 17th 05 08:23 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 07:27 AM |
