#61
I would not have felt qualified to determine whether it was flyable or
not, so I probably would not have flown it without getting an opinion and a ferry permit from an A&P (and I am not above making the A&P fly with me). My main concerns would be weakened attach points and possibly some sort of flutter induced by disrupted airflow over the aileron. That is exactly how I felt (although I was less concerned with the permit itself). I was getting lots of advice but it felt good to have an A&P come out and give me his opinion. It would have been nice to get the opinion of an aerospace engineer but I wasn't going to hold my breath for that. I did have the A&P come with me on the test flight after the repair before I put the family in the plane. My main concern had also been flutter resulting from the uneven surface. My broker seems to believe that it would be very unlikely that this will effect my rates in the future. I"m hoping that they are able to collect from the truck's Mexican liability policy too. BTW: I wonder how often people drop their plane off for annual and the mechanic borrows parts off it to retrieve another plane without the owner ever knowing ![]() -Robert |
#62
![]() "Dave Butler" wrote in message news:1143128184.860637@sj-nntpcache-3... Dave Butler wrote: Dave Stadt wrote: "Dave Butler" wrote in message news:1143124006.95524@sj-nntpcache-5... Dylan Smith wrote: On 2006-03-23, Morgans wrote: Flutter scares the crap out of me. I would strongly doubt (based on what I know) that there was even the remotest chance of flutter. From what I understand, flutter would require the flexing of the wing structure in such a way to cause the whole thing to oscillate. This happens with experimental airframes (or used to happen) because the whole surface or wing would warp under aerodynamic loads in such a way that you'd get the oscillation. A dent in a Mooney aileron isn't going to cause that. FWIW, Mooney ailerons are required to be rebalanced after they are *painted*. As are almost all flight control surfaces on most all aircraft. OK, I thought this requirement came from manufacturers service letters and the like. I know about Bonanza and Mooney. Is there some other more general requirement? Here's a quote from http://www.avweb.com/news/maint/182829-1.html "Getting Good Paint" by Paul Bertorelli: "Guenther and better shops insist—rightly—that controls be removed, stripped, inspected and, most important, rebalanced after painting. On some controls—Bonanza ruddervators and Mooney ailerons—this is a critical task and shouldn’t be skipped. But it should still be standard on all aircraft. Guenther goes so far as to record the balance data in the aircraft logbook, along with the signoff for the paint itself." which makes me think this is not a general requirement or practice. It is. Most all manufacturers provide control surface balance requirements. Even the Cessna 150 requires it. I also believe it is in the FARs. |
#63
Flutter is caused by imbalanced movable surfaces. When the
plane moves the moment arm of the surface causes deflection of the surface. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "nrp" wrote in message oups.com... | Flutter is determined by the torsional stiffness (and mass) of the wing | section. In this case, that did not seem to be compromised - i. e. | there were no diagonal wrinkles across the wing panel. If there were | diagonal wrinkles, flutter would be a real possibility. But dropping | the airspeed greatly helps the flutter margin, just as increasing the | max speed quickly reduces the flutter margin. I understand that during | each new aircraft's flight at the factory, the test pilot must dive it | to 110% of the indicated red line speed. The survivors are certfied. | | There were diagonal wrinkles across the aileron panel, but I don't | think the aileron in itself can flutter. The question in this case | would be the aileron control integrity. Someone earlier suggested | blocking or locking one aileron. That could have all sorts of | interesting changes and very definitely I would not recommend. | |
#64
Family values?
We all get there together, where the plane goes. "Daddy, why are we dead?" -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Robert M. Gary" wrote in message oups.com... | I would not have felt qualified to determine whether it was flyable or | not, so I probably would not have flown it without getting an opinion | and a ferry permit from an A&P (and I am not above making the A&P fly | with me). My main concerns would be weakened attach points and possibly | some sort of flutter induced by disrupted airflow over the aileron. | | That is exactly how I felt (although I was less concerned with the | permit itself). I was getting lots of advice but it felt good to have | an A&P come out and give me his opinion. It would have been nice to get | the opinion of an aerospace engineer but I wasn't going to hold my | breath for that. I did have the A&P come with me on the test flight | after the repair before I put the family in the plane. My main concern | had also been flutter resulting from the uneven surface. | My broker seems to believe that it would be very unlikely that this | will effect my rates in the future. I"m hoping that they are able to | collect from the truck's Mexican liability policy too. BTW: I wonder | how often people drop their plane off for annual and the mechanic | borrows parts off it to retrieve another plane without the owner ever | knowing ![]() | | -Robert | |
#65
Family values?
We all get there together, where the plane goes. "Daddy, why are we dead?" Jim, I'm not sure what type of stupid statement you are trying to make. The plane was fixed (minus mismatched paint). How many years do you normally require a plane sit idle after the A&P repairs the plane before you fly it?? -Robert |
#66
Was it repaired and completely inspected or were more
repairs done on return to the USA? The indications that I had from the thread was that more repairs/inspections were done on the airplane after it returned to the US. Yet you carried your family after major repairs caused by damage. Glad you got away with it, but what would you have done had the bell crank on the aileron been damaged and stuck the aileron full up or down? What would have done if something else was hidden in the controls that was not repaired? You obviously had a question, why else did you start this thread? FAR requires a test flight after repairs and that you, the pilot doing the test make a logbook entry, right after the A&P release to service, before any passengers are carried. Without a ferry permit [special airworthiness certificate] the A&P can only return the aircraft to service if it is in the same condition as a "new airplane" or all repairs are completed. If you are stopped by the FAA on a ramp check, hope all your paperwork is perfect. -- James H. Macklin ATP,CFI,A&P "Robert M. Gary" wrote in message ups.com... | Family values? | | We all get there together, where the plane goes. "Daddy, | why are we dead?" | | Jim, | | I'm not sure what type of stupid statement you are trying to make. The | plane was fixed (minus mismatched paint). How many years do you | normally require a plane sit idle after the A&P repairs the plane | before you fly it?? | | -Robert | |
#67
repairs done on return to the USA? The indications that I had from the thread was that more repairs/inspections were done on the airplane after it returned to the US. Yet you carried your family after major repairs caused by damage. Quoting from the original post "I was able to call an A&P to come down to Mexico and swap it for me." Sadly, the other Mooney owners wants his back (go figure) so yes, more repairs were also done back home (like ordering a factory new aileron for me, paint etc). Yes it was inspected in Mexico by the A&P doing the work and all wing panels relevant to aileron control were removed before the A&P got in the plane with me and we performed the test flight. I honestly don't know what else to do with regard to inspection other than having had the A&P look at it. I could ask Mooney if they want to send an engineer down but I don't think that is going to happen. Jim, I'm still highly offended by your comment about my family. -Robert |
#68
But I understand flutter also relies on the original torsional
stiffness of the wing being preserved. That if it is not (i. e. a wrinkled wing skin) the flutter margin is reduced. Might even a properly balanced control surface still flutter if the primary wing stiffness is compromised? or is the control surface CG the only determining item? THX |
#69
![]() "Robert M. Gary" wrote in message ups.com... Quoting from the original post "I was able to call an A&P to come down to Mexico and swap it for me." Sadly, the other Mooney owners wants his back (go figure) so yes, more repairs were also done back home (like ordering a factory new aileron for me, paint etc). Yes it was inspected in Mexico by the A&P doing the work and all wing panels relevant to aileron control were removed before the A&P got in the plane with me and we performed the test flight. I honestly don't know what else to do with regard to inspection other than having had the A&P look at it. I could ask Mooney if they want to send an engineer down but I don't think that is going to happen. Jim, I'm still highly offended by your comment about my family. -Robert IMHO you did everything that could have reasonably been expected. |
#70
Then you answered the question, IF you really had a complete
repair and the A&P did make a "return to service" entry. If he did all that and you did a test flight [you really should not have carried a passenger, which the A&P would be] and made the pilot's return to service after test flight, then what was your question, should you have just flown it away without any work/inspection or repair? As for your family, my comment was about your judgment, if you want to substitute three strangers from the beach, that's fine with me. BTW, since some FAA types read these groups, they have your N number. "Robert M. Gary" wrote in message ups.com... | Was it repaired and completely inspected or were more | repairs done on return to the USA? The indications that I | had from the thread was that more repairs/inspections were | done on the airplane after it returned to the US. Yet you | carried your family after major repairs caused by damage. | | Quoting from the original post "I was able to call an A&P to come down | to Mexico and swap it for me." Sadly, the other Mooney owners wants his | back (go figure) so yes, more repairs were also done back home (like | ordering a factory new aileron for me, paint etc). Yes it was | inspected in Mexico by the A&P doing the work and all wing panels | relevant to aileron control were removed before the A&P got in the | plane with me and we performed the test flight. I honestly don't know | what else to do with regard to inspection other than having had the A&P | look at it. I could ask Mooney if they want to send an engineer down | but I don't think that is going to happen. | | Jim, I'm still highly offended by your comment about my family. | | -Robert | |
Cirrus chute deployment -- an incredible story | Michael182/G | Instrument Flight Rules | 48 | July 14th 05 03:52 PM |
My first lesson | Marco Rispoli | Aerobatics | 3 | May 17th 05 08:23 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 07:27 AM |
