IFR hold short line at uncontrolled airports?
Old May 28th 04, 01:15 AM
Teacherjh
The longer runways are more likely to have critical areas.
Why?
Jose
(for Email, make the obvious changes in my address)
Old May 28th 04, 02:17 AM
David Megginson
Why?
The localizer will be closer to the (opposite) runway threshold.
All the best,
David
Old May 28th 04, 02:24 AM
Roy Smith
In article
ogers.com,
David Megginson wrote:
Why?
All the best,
David
Why should runway length affect how far the localizer antenna is from
the runway end?
Localizers are designed to have a fixed width (something like 700 ft
lateral displacement for full-scale deflection on the CDI) at the
arrival threshold, so longer runways will have narrower angular beam
widths. But (to the best of my knowledge) this is done by adjusting the
spacing of the transmitting elements on the localizer array, not by
adjusting the distance of the array from the runway end.
Old May 28th 04, 02:02 PM
Steven P. McNicoll
"David Megginson" wrote in message
le.rogers.com...
So what?
Old May 28th 04, 03:01 AM
Newps
"Teacherjh" wrote in message
Why?
Because the localizer spreads out at a constant rate. The longer the runway
the wider it will be at the end of the runway.
Old May 28th 04, 12:33 PM
Steven P. McNicoll
"Newps" wrote in message
runway
But the localizer critical area doesn't extend to the end of the runway.
For a category I ILS it typically extends only 2000 feet from the antenna
array.
Steven P. McNicoll
The longer runways are more likely to have critical areas. Runways whose
taxiways get too close to the runway is also a factor. We have that
problem
here at BIL. The last 3000 feet of taxiway angles in toward the runway
creating the need for an ILS hold area because you get in the way of the
localizer.
The ILS hold at BIL is near the east end of runway 10L/28R. It's there to
protect the localizer for the ILS RWY 10L, not the localizer for the ILS RWY
28R.
Old May 27th 04, 04:17 PM
Ron Natalie
"Newps" wrote in message ...
The glideslopes are as they are all positioned to bring you to the same spot
on every runway. The localizer is sited so it is a certain width at the
approach end of the runway, therefore they will move the localizer antenna
closer to or farther away from the departure end of the runway to achieve
that.
Of course, the localizer is off the end of the runway. The glideslope is in the
vicinity of the touchdown zone. Since they don't last too long if they stick then
in the touchdown zone, you've got at least two possibilities for siting (one on each
side of the runway).
Old May 28th 04, 05:51 AM
Tom Sixkiller
spot
that.
They can't "focus" or "tighten" the signal for longer runways???
Old June 9th 04, 04:47 AM
J Haggerty
Yes, they can adjust the localizer width. An example is listed below for
Billings MT ILS. (BIL) If you scroll through the data, you'll notice the
LOC width is listed as 3.34 degrees under AFIS DATA.
JPH
Date:06/08/04 22:37pm * * * ILS INQUIRY - ACTIVE * * * DATUMS Horz:
NAD83 Vert: NAVD88 CTRY: US
AIRPORT: BILLINGS LOGAN INTL ARPT-ID: KBIL RWY: 10L LCTN: BILLINGS ST:
MT REG: NM FIFO: SAC OWN: F
* * * AFIS DATA * * *
IDENT BIL GLA N45-48-44.87 GS-OFF L350 GS-LC-DIS 10875
RW-BRG 111.71 GLO W108-33-00.63 GS-OM-DIS 39546 LC-OFF
FREQ 110.300 GS-ANG 3.00 GS-TH-DIS 1135 LC-FCB 111.71
MVAR 1990/E14 GS-WID 0.70 TH-HGT 3584 LC-BCB 291.73
CAT I GS-HGT 3571.5 RE-HGT 3488 LC-WID 3.34
R-LDG-LGTH 10518
* * * LOCALIZER * * * (DFL CODE - ILS/L)
ANT LAT N45-48-01.93 XMTR SINGLE LOC-RE 1492/ 0.246 LCW-TAIL YES
ANT LON W108-30-39.88 EQUIP-TYPE ST LOC-TH 12010/ 1.977 LCW-FT-TH 700
ELEV 3491.9 STBY-POWER G LOC-IM DATE-COMM 12/18/87
ANT-TYPE LOG-PER ESV N LOC-MM 15179/ 2.498 DATE-RECON
DUAL-FREQ NO RESTRICTED N LOC-OM 50421/ 8.298 SURVEY-ACCY 8
US-DIST: FC 7989/ 18.0 BC LOC-FAF VOICE NONE
CLRNC-CVG:FC 90/31 150/30 BC MON-AL-WID W 3.90 N 2.78 REC TYPE
CKPT-DESC: FC LOM(8.28NM) TO LOC BC
LOC-WIDTH-MX-ALERT: 3.68/ 3.00 LOC-AL-MX-ALERT: 9uA ROLLOUT: S
LOC-WIDTH-INITIAL: 3.81/ 2.87
spot
that.
Hold "as published"? John Clonts Instrument Flight Rules 83 November 13th 03 03:19 PM
CAD outline of Rans S6S instrument panel? Rob Turk Home Built 2 October 21st 03 09:27 PM
