2006 Annual -- My 8th "Owner-Assisted" Inspection
Old March 24th 06, 12:47 AM posted to rec.aviation.owning
Default 2006 Annual -- My 8th "Owner-Assisted" Inspection
"Ross Richardson" wrote in message
I have an old Pointer with no panel switches. I believe that this new
remote requriement is to be sure you have an easy way to activitate the
ELT should it not go off when it should. I was surprised how easy it was
to set one off just by holding correctly and swinging it at arms length.
No force required.
The ELT is a mass, and you are accelerating it by "swinging it at arms
length".
That is a force, by definition.
Perhaps you meant "no impact/jolt required"?
Jeff Shirton (PP-ASEL)
Old March 24th 06, 02:34 AM posted to rec.aviation.owning
I recall the impact trigger spec for an ELT is 10 gs of acceleration
(for ? milliseconds?). It should take a very violent arm shake to hit
10 gs. I understand it is common to bounce the ELT onto an inflated
A/C tire to get the ~10g pulse. Anyone know the rest of the numbers?
Old March 29th 06, 01:28 AM posted to rec.aviation.owning
For ours one good shake did the trick... No need to thow it against
anything...
Toasted my engine Kobra Instrument Flight Rules 59 September 27th 05 12:16 AM
Toasted my engine Kobra Owning 59 September 27th 05 12:16 AM
Toasted my engine Kobra Piloting 61 September 27th 05 12:16 AM
Annual Report Final. "Long" NW_PILOT Owning 20 October 28th 04 07:20 PM
Annual Report Final. "Long" NW_PILOT Piloting 22 October 28th 04 07:20 PM
