Sea Harrier vertically landing with unused missiles
Old March 24th 06, 05:03 AM posted to sci.military.naval,rec.aviation.military,rec.aviation.military.naval
Default Sea Harrier vertically landing with unused missiles
Brian Sharrock wrote:
"KDR" wrote in message
Could Sea Harrier FRS1 safely land vertically with two unused Sea
Eagles attached in hot weather condition?
Your question evokes the immediate response ... insufficient data.
Read the ODM ... (Operating Data Manuals)
The manual consisted of lots of charts and a 'data point' can be extracted
by 'entering' one chart with a condition (say weight) against 'day' (ISA + n
deg) then perhaps taking that datapoint onto another chart reading off
height (above mean sea level) which might give you an answer to your
question.
Of hand; - two minutes after take-off from Nairobi in mid-summer... ?
whereas after a two hour sortie from the Falklands in mid-winter ... ?
Context, as they say, is everything.
Brian
OK, could Sea Harrier FRS1 safely land vertically on the Invincible
class carrier in the South China Sea in mid-summer with two unused Sea
Eagles after a two-hour mission?
Was there any case the FRS1 had to jettison unused Sea Eagles before
landing on the carrier?
Old March 24th 06, 10:21 AM posted to sci.military.naval,rec.aviation.military,rec.aviation.military.naval
extracted
+ n
question.
Brian
Sorry, but you would have to read the ODM. If you don't have access to the
data you probably aren't authorised to have it. [its tough, but it's life]
..If you have a legitimate need-to-know; try posing the question to the
manufacturer's marketing department.
Brian
Old March 24th 06, 09:29 PM posted to sci.military.naval,rec.aviation.military,rec.aviation.military.naval
question.
Brian
I would imagine that after 2 hours the fuel load would be so reduced
that the weight of the missiles wouldn't come into the equation.
Dumping missiles would get one on jankers quicksmart
Old March 25th 06, 10:04 PM posted to sci.military.naval,rec.aviation.military,rec.aviation.military.naval
In rec.aviation.military KDR wrote:
snip
The trivial way would be to look up the weight of a Sea Eagle.
600Kg per.
So, 1200Kg.
The first site I found gave 2295Kg of fuel for a model of the harrier.
So, if it can land fully fueled, but without the eagles, then it can
land with about half and them.
Assuming no COG/... issues.
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Most reliable homebuilt helicopter? tom pettit Home Built 35 September 29th 05 03:24 PM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 12:35 PM
Cuban Missle Crisis - Ron Knott Greasy Rider© @invalid.com Naval Aviation 0 June 2nd 05 10:14 PM
