In article , "Highflyer"
wrote: wrote in message oups.com... Snip lots of good stuff from our #1 common sense expert! I'm right-handed; a North-paw. So are my portable saws. When making the tapered cuts the work bench is on my right hand side. To make the cut I simply walk along beside the work bench, pushing the saw and making sure it stays in contact with the guide. I'm not supporting anything - - the work bench is doing that. My back is straight (or nearly so), my weight is balanced over my hips and I can make the cut as fast or as slow as I wish; there's no physical strain. Bottom Line is a straight, accurate cut. But when you have a LEFT-HAND saw, for this particular job it means the work bench should be on your left and, ideally, you should be guiding it with your left hand. Of course, if you happen to be right-handed, things can get a bit awkward. Which is why they make both right- and left-handed saws, a fact some folks were not aware of. -R.S.Hoover Interestingly most of the old SKIL worm drive saws I have seen have been right handed. Both of mine are. On the other hand, the large majority of the common direct drive power saws sold by Sears, and other such places are left handed. I have a couple of those also and both are LEF T handed. I have often wondered why this is so. Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) Note: The 2006 P'Ville flyin is May 19, 20, and 21. Start your planning now. Email Mary at so she will have the right groceries on hand so we can feed you at mealtimes! I'm not so sure that I agree with this right-hand, left-hand saw business. What is a right hand saw for rip cuts is a left-hand saw for cross cuts, and vice versa. Since, as Mr. Hoover himself pointed out, most people would use a table saw for rip cuts, the handheld saw of circular or sabre genre is generally relegated to shorter cross cuts. For that application, it is normal for a right-handed person to support the workpiece on sawhorses in front of him, with the "waste" end extending to one's right. Presto chango, left-hand saw becomes right-hand saw. |
Never used the Skill for cutting aluminum, but - - ! Mine is
30-couple years old, a worm-drive model. The grips are positioned for the right hand to hold the main grip, and to hold the switch. The other grip is atop the housing, forward, and angled appropriately for gripping with the left hand. The big shoe is to the LEFT. Does that make it a north or south? Interesting, thanks. Flash |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
Four States and the Grand Canyon | Mary Daniel or David Grah | Soaring | 6 | December 6th 04 10:36 AM |
Discovery Wings Channel ??? | Andy Asberry | Home Built | 0 | November 13th 04 05:11 AM |
Stolen "Champ" wings located...from 23,000 feet!! | Tom Pappano | Piloting | 17 | December 15th 03 01:24 PM |
Wings from "Champ" stolen in Oklahoma after emergency landing | Tom Pappano | Piloting | 1 | December 7th 03 05:02 AM |
