"Barry" wrote in message
... The current PTS is FAA-S-8081-4C with changes 1 and 2. Change 2 added the Rating Task Table and was issued 3/11/99. I couldn't find it online so I posted it on alt.binaries.pictures.aviation. Thank you... much appreciated. In reviewing the original version 4C as well as changes 1 and 2, I think it could reasonably be said that the "IPC task list" is the list of items from which FAR 61.57 allows the instructor to select a "representative" number of tasks. I believe that is how/why an IPC can be conducted today in an FTD or advanced ATD without a circling approach; there is no explicit statement that all of the IPC tasks must be included in an IPC, so I would conclude a CFII has the discretion to select a representative number of the tasks from the IPC task list. The new "gotcha" item which grabs my attention in the new version 4D PTS is the following on page 16 -- note in particular the last sentence which I have quoted: Instrument Proficiency Check. 14 CFR part 61.57(d) sets forth the requirements for an instrument proficiency check. The person giving that check shall use the standards and procedures contained in ths PTS when administering the check. A representative number of TASKs, as determined by the examiner/instructor, must be selected to assure the competence of the applicant to operate in the IFR environment. As a minimum, the applicant must demonstrate the ability to perform the TASKs as listed in the above chart. -------------------- Richard Kaplan, CFII www.flyimc.com |
could reasonably be said that the "IPC task list" is the list of items from which FAR 61.57 allows the instructor to select a "representative" number of tasks. I believe that is how/why an IPC can be conducted today in an FTD or advanced ATD without a circling approach; there is no explicit statement that all of the IPC tasks must be included in an IPC, so I would conclude a CFII has the discretion to select a representative number of the tasks from the IPC task list. The new "gotcha" item which grabs my attention in the new version 4D PTS is the following on page 16 -- note in particular the last sentence which I have quoted: Instrument Proficiency Check. 14 CFR part 61.57(d) sets forth the requirements for an instrument proficiency check. The person giving that check shall use the standards and procedures contained in ths PTS when administering the check. A representative number of TASKs, as determined by the examiner/instructor, must be selected to assure the competence of the applicant to operate in the IFR environment. As a minimum, the applicant must demonstrate the ability to perform the TASKs as listed in the above chart. The old PTS doesn't include that wording, but on page 3 it says: "Applicants for an instrument proficiency check required by 14 CFR section 61.57, must perform to the standards of the TASKS listed under PC in the Rating Task Table on page 15." The FAA's Part 61 FAQ (http://www.faa.gov/avr/afs/afs800/docs/pt61FAQ.doc) says : ---------------------- QUESTION: Request guidance on the meaning/intent of the wording ". . . a representative number of tasks. . ." ANSWER: Ref. § 61.57(d): First of all, neither the regulation nor the preamble of the regulation covers what you're asking. The answer is to be found in the Instrument Rating Practical Test Standards, FAA-S-8081-4C on page 15 of the Introduction (effective with change 2 as of 03/11/99). The right hand column of the Rating Task Table indicates the required Tasks for the Areas of Operation. Historically, the wording ". . .a representative number of tasks . . ." requires an objective decision to be made by the CFII/examiner that is dependent on the applicant's ability. If it becomes obvious during the conduct of the instrument proficiency check that a pilot who has not flown instruments in over a year or more is extremely weak, then the check may need to be more extensive than the required list. The CFII/examiner needs to be able to say at the conclusion of the check that yes this pilot can operate safely in the national airspace system. -------------------- These both indicate to me that the FAA intends for the IPC to require all of the listed items. However, it's not clear that this is legally binding on a CFII. Page 1 of the current PTS says: "The Flight Standards Service of the Federal Aviation Administration (FAA) has developed this practical test standards book to be used by FAA inspectors and designated pilot examiners when conducting instrument rating—airplane, helicopter, and powered lift practical tests, and instrument proficiency checks for all aircraft." There's no mention of instructors, so one could argue that it's mandatory for examiners but not plain old CFIIs. I have been treating it as mandatory. I suppose you could ask your local FSDO (who I assume approved your FTD) for their interpretation, but you might not like the answer you get. Barry |
... There's no mention of instructors, so one could argue that it's mandatory for examiners but not plain old CFIIs. I have been treating it as mandatory. Interesting.. the latest version of the PTS seems even more permissive in that regard: ------------------------- FAA inspectors and designated pilot examiners shall conduct practical tests in compliance with these standards. Flight instructors and applicants should find these standards helpful during training and when preparing for practical tests. ------------------------- This preamble seems to imply that the PTS is just a helpful reference, presumably a reference from which to draw "representative tasks" per 61.57. -------------------- Richard Kaplan, CFII www.flyimc.com |
... These both indicate to me that the FAA intends for the IPC to require all of the listed items. However, it's not clear that this is legally binding on a CFII. Page 1 of the current PTS says: If all the listed items were legally binding on a CFII, then a huge number of IPCs issued by FlightSafety, Simcom, and RTC since 1999 would be invalid because landing out of an approach is required, yet only Level C and Level D simulators qualify to log landings according to the chart at the end of the 1999 PTC. -------------------- Richard Kaplan, CFII www.flyimc.com |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
CFI logging instrument time | Barry | Instrument Flight Rules | 21 | November 11th 03 12:23 AM |
Instrument Rating Ground School at Central Jersey Regional (47N) | john price | Instrument Flight Rules | 0 | October 29th 03 12:56 PM |
Instrument Rating Ground School at Central Jersey Regional (47N) | john price | Instrument Flight Rules | 0 | October 12th 03 12:25 PM |
Use of hand-held GPS on FAA check ride | Barry | Instrument Flight Rules | 1 | August 9th 03 09:25 PM |
