Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Products
Need help with Narco LORAN LRN 840
Old March 19th 06, 11:40 PM posted to rec.aviation.products,rec.aviation.owning,rec.aviation.ifr
Default Need help with Narco LORAN LRN 840
That is your choice and problem, there is no free lunch.
"Benjamin Gawert" wrote in message
| Jim Macklin schrieb:
| Former cases from the EAA? Are you a member? If not
join?
| It is not restricted to USA only.
| I'm not a member, and paying the membership for a ~20yr
old LORAN unit
| is hardly worth it.
| Benjamin
Old March 20th 06, 03:25 AM posted to rec.aviation.products,rec.aviation.owning,rec.aviation.ifr
Pins A-F: Not used
Pins H-J: GND
Pin K: + LEFT
Pin L: Not used
Pin M: - NAV FLAG
Pin N: Digital data common
Pins 1-6: Not used
Pin 7: + 14/28 VDC power in
Pin 8: Not used
Pin 9: + RIGHT
Pin 10: Not used
Pin 11: + NAV FLAG
Pin 12: Digital data out
Benjamin Gawert wrote:
I got an old NARCO LRN-840 LORAN-C that I want to reanimate. Sadly I
only got the unit itself, no manuals or cables. What I need is a pinout
of the rear card-edge connector and informations about what voltage it
requires etc. If someone has a manual as pdf or any other electronic
format it would be great if he'd mail that to me.
Benjamin
Old March 21st 06, 02:14 PM posted to rec.aviation.products,rec.aviation.owning,rec.aviation.ifr
What an attitude from someone asking for help, sheesh.
Dave S schrieb:
Thanks, but that doesn't help me much. I already did a search with
Google but sales ads for aircrafts that have such a LORAN device aren't
really helpful. And buying a manual for a price that is more than this
unit is worth is also not an option.
So if someone out there does have a Narco LRN-840 and a manual please
check out the connector pinout and post it here.
Benjamin
Actually, if you READ those google ads, you may notice that SOME are for
sales relating to the literature that you are looking for, not just
aircraft with them installed.
Well, if YOU had READ my posting you probably would have noticed that I
know that some are selling manuals...
Eastern Avionics, in particular, will likely have what you are looking
for and email you a pinout for less than $20 total. Just in case nobody
happens to have a free copy laying around.
Also check out Ebay, GEBE's Estate Sale.. they have LOTS of old avionics
documentation and I have purchased several items from them in the past.
Again, the price may be quite reasonable (but not free...)
Well, the unit is old and I even don't know if it's working, so 20$ +
shipping + tax (if you look at my email address you might notice that I'm
not in the US) is simply too much just to get the pinout of a few pins.
Benjamin
Old March 28th 06, 07:20 PM posted to rec.aviation.products,rec.aviation.owning,rec.aviation.ifr
TxSrv schrieb:
I have an LRN-820, and the pinout may be the same. Looking at the back,
top row of pins (L to R) are 1-12; bottom are A-N. GND is H & J (there
is no I pin). +14/28v is pin 7. Use a multimeter to verify. GND will
be a dead short to the case. Measure +V in to GND: with multimeter set
on high resistance, turning switch on should cause the meter to show an
increasing resistance reading until an electrolytic capacitor fully
charges. Feed in +V thru a 2-3 amp fuse for insurance. Current draw on
the 820 is .5A at 14V; .25A at 28V.
Thank you very much! This was the information I was looking for...
It probably also requires an amplified antenna. Did you get a little
amplifier box which is inserted (near antenna end) in the coax to the
antenna?
Sadly, no, just the base unit. But it's not for use in an airplane any
more but just for the fun of it, so that's not a problem at all.
Thanks again!
Benjamin
Old March 28th 06, 07:38 PM posted to rec.aviation.products,rec.aviation.owning,rec.aviation.ifr
Well, at least two other people seem to think different and have no
problem passing the informations they already have to others that are
looking for it. Thankfully there are still people that do that. Im quite
active in several other groups, and people there also just share the
informations they have. You need a pinout? Just ask, and someone who has
it probably will tell you. Honestly I'm a bit surprised about the "if
you wanna know then go and buy the information" attitude here. Where's
the problem when people that have such an unit lying around or in use or
have the manual just to pass the informations?
I simply just see no reason to sign for a membership that costs much
more than this old unit is worth (and still doesn't gurantee that I get
the informations I need), or to buy a manual for a 20yr old worthless
LORAN unit that is in unknown condition just to get the pinout of the
rear connector, especially since this is just a project for curiosity
and also since LORAN probably isn't that common navigation system any
more so there are dozens of retired units around that have no real value
any more.
YMMV, though. Maybe it's ok for you to buy i.e. a 50$ manual to repair a
20$ radio, but don't expect everyone to do the same.
Benjamin
Old March 28th 06, 11:15 PM posted to rec.aviation.products,rec.aviation.owning,rec.aviation.ifr
I understand your desire and appreciate that some people did
have the data you needed. But if they did not have that
data, your choice would be to drop the project or buy the
manual. You could even trace the circuits.
But you asked for a manual or data and I suggested a source
that was valid. You became rude because it was not free.
That is your problem, not mine. If you don't think that an
EAA membership is worth the money just for the magazine and
other functions, and all you'd get is the pin-outs, that is
again, your problem
Have a nice day.
and have no
others that are
that. Im quite
share the
someone who has
about the "if
here. Where's
around or in use or
costs much
gurantee that I get
old worthless
pinout of the
for curiosity
system any
no real value
| any more.
manual to repair a
| Benjamin
Need help with Narco LORAN LRN 840 Benjamin Gawert Owning 18 March 28th 06 11:15 PM
Narco 120 replacement/TKM 11x of ICOM A200 Jerry Springer General Aviation 0 January 23rd 04 02:45 AM
Narco 120 replacement/TKM 11x of ICOM A200 Jerry Springer Aviation Marketplace 0 January 23rd 04 02:44 AM
Narco 120 replacement/TKM 11x of ICOM A200 Jerry Springer Home Built 0 January 23rd 04 02:43 AM
Narco 120 replacement/TKM 11x of ICOM A200 Jerry Springer Products 0 January 23rd 04 02:43 AM
