![]() "B" wrote in message ... Kevin Brooks wrote: "B" wrote in message ... Fred J. McCall wrote: "Andrew Chaplin" wrote: :"Harry Andreas" wrote in message ... : : Damn right. : : SLAMRAAM is a box launched AIM-120. : As such, it has less range and a smaller engagement envelope than : the airborne version, but still a bugger to go up against. : :Why the loss of performance? Because you're not starting with a 600+ knot velocity when you light the motor like you are when you launch from an aircraft and because what you're shooting at is 'up' from where you're shooting from. Ye kenna violate the laws o' physics, Captain! :-) Altitude is probably more important. I doubt that. Altitude alone yields increased range only in a look down/shoot down scenario (yeah, decreased drag alone due to increased altitude will have some effect regardless of the aspect of engagement, but it will not be significant); OTOH, adding that 600 knots to the missile at launch is imparting a heck of a lot of energy--you know, that whole vee-squared part of the kinetic energy equation? Brooks Wait until you see this (check my figures please). AIM-120 (150kg) at 10,000m Ug=150kg x 10km x g =150,0000 x 10,000 x 9.8 =14.7x10^9 J AIM-120 at 600knots (300m/s) =150,000 x 300^2 =13x10^9 J Much closer than I thought. Of course it's a complex problem but the raw figures are interesting. A bigger difference than I would have thought, but a key factor to consider--the land based system is not intended to be going after high flyers; that would probably remain the territory for the Patriots (which do habitually see a number of batteries get sent forwards into the division-level sectors, they don't all remain back at corps and theater level). As described, this is supposed to be an anti-helo, anti-UAV, and anti-cruise missile system, so again, the altitude issue is probably not as great as one would think. And shouldn't that KE equation use *one-half the mass* times velocity squared? Which would make the result half of what you calculated? Brooks |
