2006 Annual Inspection -- Complete
Old March 30th 06, 01:09 PM posted to rec.aviation.owning
Default 2006 Annual Inspection -- Complete
Just curious- why did you have to replace the TKS filter? Were you getting a
high pressure indication? How long and how much do you use your system?
I have a system in my Baron, but always run the fluid through a filter
funnel when filling, and after a couple of years and many tanks of fluid it
still runs great.
Old March 30th 06, 01:27 PM posted to rec.aviation.owning
Yes, I was receiving a high pressure indication.
However... I did call the company to inquire about the high pressure
indication and one of their techs told me that low voltage can also fool
this sensor into believing there is high pressure in the lines.
At the time I was unaware that my primary alternator had failed (long
story, has to due with problems with my standby alternator sensor light
coming on for other reasons), so in hindsight, it appears that the
indication may have been erroneous.
still runs great.
I do the same, but I am the second owner of the aircraft since the system
was installed and AFAIK, the filter was never changed in the six years
since installation. Therefore I am justifying the expense of the filter
replacement as preventive maintenance.
Oh, and the mechanic did admit that the old filter looked used, so it was
only a matter of time. Flying in the northeast and downwind of the Great
Lakes, my TKS system deserves a lot of TLC.
Peter
Old March 30th 06, 03:30 PM posted to rec.aviation.owning
Thanks. After my initial installation I kept getting a high pressure
indication, and went through the process of changing the filter, only to
find that the wire to the panel from the sensor was crimped, leaving an open
circuit. It was a slimy and time consuming job to change the filter, which
obviously didn't solve the problem.
However, I also fly around and over the Great Lakes, and the TKS is the only
way to go short of getting into something that burns kerosene.
Old March 30th 06, 03:39 PM posted to rec.aviation.owning
From what I have heard, those pilots who fly the turboprop aircraft in the
Northeast US are never permitted by ATC to get up to the altitudes where
those aircraft really excel.
A pilot at my FBO purchased a turboprop Piper Malibu a few years ago and
admitted that no matter what he files for northeast US flights, he is only
given cruise altitudes in the mid-teens. He stated that the aircraft
prefers the mid-twenties for fuel and speed purposes, so he is actually
considering selling the aircraft.
Peter
2006 Annual -- My 8th "Owner-Assisted" Inspection Jay Honeck Owning 19 March 29th 06 01:28 AM
2006 Annual -- My 8th Owner Assisted -- Update Jay Honeck Owning 14 March 27th 06 07:11 PM
Annual Report Final. "Long" NW_PILOT Owning 20 October 28th 04 07:20 PM
Annual Report Final. "Long" NW_PILOT Piloting 22 October 28th 04 07:20 PM
