OLC participation and "red marks"
Old March 31st 06, 08:30 PM posted to rec.aviation.soaring
Default OLC participation and
Apparently SeeYou has the same workaround implemented. You need to
download a xip file with the patches and replace the files in your
SeeYou directory:
http://www.naviter.si/dload/seeyou-cai-dos.zip
1. Extract both files from the ZIP to your SeeYou folder
2. Replace your existing SeeYou.exe
You should be able to claim flights normally once the patches are
applied.
Hopefully this will clear up the problems with the Cambridge 10/20/25
loggers and OLC. Please post your experiences with either program and
the older Cambridge loggers.
Old April 3rd 06, 08:30 PM posted to rec.aviation.soaring
Well, I don't see any postings from this weekend. Is no news good news?
As info, the SeeYou patch above had problems with long file names (it's
a DOS thing). They have a new patch up on their web site:
http://www.seeyou.si/news/2006/04/gps-nav-patch.html
Old April 3rd 06, 08:40 PM posted to rec.aviation.soaring
I see 63 postings with over 50 points, and 20 of them have the red mark.
If you use this patch, do you still get the OLC message "Sorry,
Validation Service is current not running.
OLC Team is working on that issue," or has SeeYou figured a way around
that message?
Old April 7th 06, 11:32 PM posted to rec.aviation.soaring
QT reported success with the SeeYou patch on Cambridge files from KS,
X, QV and SM on 4/4. All were uploaded and validated without problems.
The only red marks in the SSA-OLC in the last few days are from people
using GPSlog (not sure why that did not work) or test download on the
Volkslogger.
BTW, SeeYou found another issue with long directory names, and have
reposted a patch yesterday April 6 to correct this:
OLC also has more Cambridge info on their Info page:
http://www.onlinecontest.org/olcphp/olc-i.php?olc=olc-i
Old April 8th 06, 02:45 AM posted to rec.aviation.soaring
Doug, do you know the exact time of the Tuesday upload cutoff? Your
presentation says 0000 zulu, but it appears that one usually can upload
after that time. The OLC website is unclear.
Volkslogger.
Old April 8th 06, 12:45 PM posted to rec.aviation.soaring
It should have said 2400z Tuesday, or 0000z Wednesday.
Old April 8th 06, 05:08 PM posted to rec.aviation.soaring
But is that the actual cutoff, or are they giving until midnight USA time?
Old April 9th 06, 03:20 PM posted to rec.aviation.soaring
There is also a freeware utility for Cambridge GPS-NAV flight claiming
to OLC written by Carl Ekdahl available on the ASC website:
http://www.abqsoaring.org/misc_files/CAI_fix.htm
So now, there should be no more red marks for Cambridge!
If you got a red mark yesterday (or know someone who did) please try
reclaiming the flight with one of these programs.
Old April 9th 06, 07:24 PM posted to rec.aviation.soaring
Uh, I'm guessing there are quite a few pilots world-wide who
done read the Albuquerque site, who don't read RAS, and in general
get very frustrated with anything to do with computers. The
problem's not going away anytime soon.
The See-You patch is likely only valid for 3.X versions, something
that's been left off the See-You and OLC sites.
"red oxide primer is a plus" mhorowit Home Built 6 November 27th 05 05:23 PM
