Cracked ribs
Old April 1st 06, 04:52 AM posted to rec.aviation.piloting
Default Cracked ribs
Larry Dighera wrote:
If we're discussing PA28's, there was a mandatory service bulletin for
inspection of the wing spars that required removal of the wing tanks
issued around August 1996, IIRC. Have you had that inspection
performed?
SB 1006...yep, it was done a couple years ago. IMHO, this is a
mandatory SB to perform as part of buying a PA28.
Jack Allison
PP-ASEL-Instrument Airplane
Arrow N2104T
"When once you have tasted flight, you will forever walk the Earth
with your eyes turned skyward, for there you have been, and there
you will always long to return"
- Leonardo Da Vinci
(Remove the obvious from address to reply via e-mail)
Cracked cylinder: Typical cause? Peter R. Owning 19 October 9th 04 04:24 AM
Testing Stick Ribs Bob Hoover Home Built 3 October 3rd 04 02:30 AM
How much to replace cracked crankshaft in 1972 skyhawk O-320-E2D engine Dave Gribble Owning 2 February 4th 04 08:30 AM
Heat treating wing ribs Holger Stephan Home Built 13 February 3rd 04 11:59 PM
Is a cracked vent SCAT tube an urgent problem? Ben Jackson Owning 18 September 20th 03 03:31 AM
