![]() john smith wrote: Dan, I have a couple hundred hours behind the normally aspirated 0-470 Continental in C182's. Anytime there is significant moisture in the air, the carb will ice up. Not true. I recently sold my 182 after having put 1000 hours on it. Never had it ice up, even after trying. I would go out on those rare days here when we had fog and fly just as it lifts, still 90 somethun' percent humidity. Couldn't make it happen. I will not fly with carb heat on constantly. I read somewhere in the past (years ago, don't recall where) that flying with constant carb heat moves the ice farther down the throat where no heat will be available to melt it. Old wives tale. Cessna Pilots Assoc reccomends whatever amount of carb heat is necessary to keep the carb at about 45 degrees in cruise. Also has the effect of evening out the fuel mixture so the engine ran smoother. |
Newps wrote: john smith wrote: Dan, I have a couple hundred hours behind the normally aspirated 0-470 Continental in C182's. Anytime there is significant moisture in the air, the carb will ice up. Not true. I recently sold my 182 after having put 1000 hours on it. Never had it ice up, even after trying. I would go out on those rare days here when we had fog and fly just as it lifts, still 90 somethun' percent humidity. Couldn't make it happen. Okay, I will rephrase my statement, temperature and humidity have to be in the proper range. It can be too warm or too cold, but with significant moisture in the proper range, the O-470 Continental in a Cessna 182 will likely form carb ice. |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Hurricane relief | Dave Stadt | Piloting | 94 | September 8th 05 07:02 PM |
Hurricane relief | Gary Drescher | Instrument Flight Rules | 51 | September 8th 05 03:33 AM |
Military jet makes emergency landing at MidAmerica | Otis Willie | Military Aviation | 0 | September 1st 03 02:28 AM |
First Emergency (Long Post) | [email protected] | Owning | 14 | July 23rd 03 02:46 AM |
