phil collin wrote: Ok, Glen, would you agree with Jack on the aero tow speed? seems a bit on the high side that's all. We fly IS30's, IS28's, Blaniks, Darts, Pirats, Skylarks, libelles etc and we generally tow them all at 60 Knots without any issue, does the PiK fly better with a quicker tow? also, the reading I've done suggests best L/D at 63 Knots, does that sound right? Thanks to you and Jack I fly a 301 Libelle, towing on the CG hook. It's the CG hook that is the issue with slow tows. Gliders generally have small elevators, some smaller or less effective than others. Towing on the CG hook loads up the tailplane more than towing with a nose hook, so, at low tow speeds, one can run out of elevator authority. This is especially dangerous in gusty conditions where there may be momentary hard yanks on the tow line adding to the tendency to pitch up. God help you if you have an aft CG in that situation. I have had a tow or two where the speed got down below 50 knots. That was very uncomfortable and I was reaching for the tow release in each case while yelling at the tuggy for more speed. |
PDA mount in PIK20B | Derrick Steed | Soaring | 1 | May 22nd 04 02:31 AM |
