Dissimilar metals in fuel tank
Old April 5th 06, 12:06 AM posted to rec.aviation.homebuilt
Default Dissimilar metals in fuel tank
I'm in the process of building my fuel tanks. On the insiide I was
going to have stainless steel bolts going through the tank to hold to
an aluminum bracket. I really don't know much about the metal industry
but do remember that there can be a problem with dissimilar metals. Do
anyone know if this will be a problem, especially with the fuel?
Lou
What's the difference between active and passive stainless steel then ? How
can you tell the difference between the two for a given stainless steel
screw or bolt ?
Old April 8th 06, 08:12 PM posted to rec.aviation.homebuilt
Lou
screw or bolt ?
IIRC 'passivation' is a process wherein the stainless steel is treated
with
acid to remove any iron from the surface so that only nickle and
chromium oxides are in contact with the environment.
IOW, you send your weldment out to be passivated after you
hare done fabricating it. FOr bolts, you'd buy them already
passivated, assuming such things are available.
FF
Replacing fuel cut-off valve with non-a/c part??? Michael Horowitz Owning 46 January 15th 05 10:20 PM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
