It is an official term, in the pilot/controller glossary
http://www.faa.gov/atpubs/PCG/U.HTM UNABLE- Indicates inability to comply with a specific instruction, request, or clearance. "Steven P. McNicoll" wrote in message k.net... | | "Jim Macklin" wrote in message | news:3n_Yf.8891$t22.4772@dukeread08... | | The PIC can always say UNABLE, a magic word to controllers. | | | How so? | | |
![]() "Jim Macklin" wrote in message news:NJ%Yf.8900$t22.5226@dukeread08... It is an official term, in the pilot/controller glossary http://www.faa.gov/atpubs/PCG/U.HTM UNABLE- Indicates inability to comply with a specific instruction, request, or clearance. That makes it a magic word? |
Because ATC can't question you further, you've stated that
you are UNABLE to do whatever it is that they wanted, such as a turn into a thunderstorm, or a land and hold short. No need to argue, just say unable and then tell them what you can do... saves a lot of time. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Steven P. McNicoll" wrote in message ink.net... | | "Jim Macklin" wrote in message | news:NJ%Yf.8900$t22.5226@dukeread08... | | It is an official term, in the pilot/controller glossary | http://www.faa.gov/atpubs/PCG/U.HTM | | UNABLE- Indicates inability to comply with a specific | instruction, request, or clearance. | | | That makes it a magic word? | | |
![]() "Jim Macklin" wrote in message news:ja8Zf.9077$t22.4360@dukeread08... Because ATC can't question you further, you've stated that you are UNABLE to do whatever it is that they wanted, such as a turn into a thunderstorm, or a land and hold short. No need to argue, just say unable and then tell them what you can do... saves a lot of time. Well, just saying UNABLE doesn't magically tell them what you intend to do. |
No, but it puts them on the "what do you want to do" rather
than the do as I say. "Steven P. McNicoll" wrote in message k.net... | | "Jim Macklin" wrote in message | news:ja8Zf.9077$t22.4360@dukeread08... | | Because ATC can't question you further, you've stated that | you are UNABLE to do whatever it is that they wanted, such | as a turn into a thunderstorm, or a land and hold short. No | need to argue, just say unable and then tell them what you | can do... saves a lot of time. | | | Well, just saying UNABLE doesn't magically tell them what you intend to do. | | |
![]() "Jim Macklin" wrote in message news:dKcZf.9737$t22.1840@dukeread08... No, but it puts them on the "what do you want to do" rather than the do as I say. That appears to be a question. You said that ATC can't question you further, once you've stated that you are UNABLE to do whatever it is that they wanted. |
I think you're just having fun being difficult. ATC will
assign what is easiest for ATC. Any pilot can refuse any clearance. A simple UNABLE is the end of ATCs option to continue to issue that clearance. Any PIC should have the sense to offer an option of what he wants to do, what he is able to do. It could be equipment, weather, operating limitations, but saying UNABLE is clearly understood. No further reason or explanation is required. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Steven P. McNicoll" wrote in message nk.net... | | "Jim Macklin" wrote in message | news:dKcZf.9737$t22.1840@dukeread08... | | No, but it puts them on the "what do you want to do" rather | than the do as I say. | | | That appears to be a question. You said that ATC can't question you | further, once you've stated that you are UNABLE to do whatever it is that | they wanted. | | |
It's a metaphor. Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
![]() "Jose" wrote in message . .. It's a metaphor. A metaphor that the user needs to explain. |
"Magic words" (real ones, which btw do not exist) are words which, when uttered, do things that are beyond the laws of physics. They are incantations of, well, magic. Simply saying the magic words cause things to happen which ordinarily could not take place. "Please" and "thank you" are metaphorically "magic words" because by using those words, people respond differently than when the same situation is presented, but without these words. They are (of course) not =really= magical and do not invoke the other world, but because they are powerful social lubricants, they have been given this metaphorical moniker. "Mayday" and "this is an emergency" are also words which elicit a powerful response when otherwise such a response would not be forthcoming. While they do not have the power of actual magical incantations (and thus cannot put fuel in your tank) they will in general garner much more assistance than would normally be gotten without them. "Unable" is similar in this respect. By conveying that the requested action is not just inconvenient, but either unsafe or impossible, the other party is more likely to try to find a workaround, if it is possible. As with all incantations, metaphorical or otherwise, abuse leads to the wrath of the Dark Side, which may be vented on those later to come. Therefore, these magic words should be used with care. But they do have a powerful effect, even if it is not truely magical. Controllers can use these words too. "Request straight in to runway 5" (runway 5 is full of men and machines, seventy parked cars, and a large tent). "Unable runway 5, I can give you left base to runway 35. Report three miles." Generally however it is the pilots who will have the more stringent operations requirements, and will be more likely to use magic words. Jose -- Nothing takes longer than a shortcut. for Email, make the obvious change in the address. |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Outfly the wind | Doug | Piloting | 7 | July 6th 05 03:18 PM |
LX4000 wind calculation | AttentionLEcureuil | Soaring | 2 | June 23rd 04 04:33 AM |
