On Thu, 06 Apr 2006 03:26:10 GMT, Orval Fairbairn
wrote: In article .com, "Andrew Sarangan" wrote: I am using the following steps for treating my aluminum parts: - scrub clean with Acetone and scotchbrite - dry - scrub clean in Metalprep-79 and scotchbrite - rinse in water - repeat until water forms smooth sheet (water break test) - dip in alodine 1201 until part turns golden brown - rise in water After the final rinse, the golden brown coating feels soft and delicate, and could be rubbed off easily. I have to hang the part and let it completely dry before touching it. Golden brown is too much! All you need for best results is a light golden hue. Keeping it in the Alodine too long actually reduces the corrosion protection! About 10 - 20 minutes immersion should suffice. All that I've done so far (which aint much) looks more like a gold clear coat, or stain rather than an actual coating. Lots of coating and lots of washing. You can get it for steel or aluminum. I think the Alodine is the same, but the prep solution is different. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Now, I can remove the alodine by scrubbing the part again with Metalprep-79 and recover its original shiny surface. If it repeat the above surface treatment all over again, I get a more stable coating that looks more uniform and not so soft, and also appears slightly darker in color. I am not sure if I understand why this is happening. This has happened every time I tried it, not just once, so it is not a random occurence. Why is the re-coat giving me better results than the first-time coat? You can also use a weak mixture of lye and water as a prep. For best results, heat it to 120 deg F and dip the part for about 5 minutes. Yes -- the aluminum must be free of dirt and grease befor starting the process. |
Handheld battery question | RobsSanta | General Aviation | 8 | September 19th 04 03:07 PM |
Question | Charles S | Home Built | 4 | April 5th 04 09:10 PM |
Phoenix AIM-54A (QUESTION) | Krztalizer | Naval Aviation | 10 | February 23rd 04 07:22 AM |
Question for Squirrel the Lurker | jls | Home Built | 0 | January 30th 04 02:41 PM |
Partnership Question | Harry Gordon | Owning | 4 | August 16th 03 11:23 PM |
