PSRU design advantages
Old April 7th 06, 02:41 PM posted to rec.aviation.homebuilt
Default PSRU design advantages
Ernest Christley wrote:
Ian Stirling wrote:
Best tool available to the amateur is a variable speed strobe - Party Light!
That way you can actually look and SEE what's happening.
That'll spot ordinary vibrations.
Torsional ones are a little bit harder.
Especially if you want, as you probably should, a graph of maximum stress
anywhere in the shaft/PSRU/Prop system vs RPM.
A few fine white lines down the length of the shaft will clear up that
problem.
Will they?
It'll obviously show huge torsional movement, but many, especially
shorter shafts may fail before it becomes visible.
Old April 7th 06, 06:04 PM posted to rec.aviation.homebuilt
problem.
Will they?
Ian, if it won't stay together long enough to turn on the strobe,
it probably needs a little more work...
Richard
Looking for a two-seater design Shin Gou Home Built 13 December 21st 04 06:44 AM
Aircraft Design 1942 flying boats FA Sally Home Built 0 August 19th 04 06:49 PM
amateur design consultant? Shin Gou Home Built 14 June 30th 04 01:34 AM
How 'bout a thread on the F-22 with no mud slinging, no axe grinding, no emotional diatribes, and just some clear, objective discussion? Scott Ferrin Military Aviation 23 January 8th 04 12:39 AM
