Have you created anything "home-made" for your plane? (or a low cost alternative?)
Old April 9th 06, 05:06 PM posted to rec.aviation.piloting,rec.aviation.owning,rec.aviation.student
Default Have you created anything "home-made" for your plane? (or a low cost alternative?)
Instead of aluminum, use PVC water pipe. It's lighter yet and can be worked
with simple tools.
"Al Gilson" wrote in message
Instead of angle "iron" use aluminum. It's lighter.
Old April 9th 06, 05:22 PM posted to rec.aviation.piloting,rec.aviation.owning,rec.aviation.student
with simple tools.
Jim, does the PVC provide any/sufficient friction to prevent the wheels
from rolling on a slope?
Old April 10th 06, 02:58 AM posted to rec.aviation.piloting,rec.aviation.owning,rec.aviation.student
Use two different diameters, say a 2 1/2" and a 3", cut in half lengthwise.
Use one of each per set, they'll stack inside each other that way. As far
as friction, the tire should put enough down pressure against the top of the
arch so that the cut edges dig in sufficiently, if not, a smaller diameter
may work better.
Jim Burns
"john smith" wrote in message
worked
with simple tools.
Old April 10th 06, 03:53 AM posted to rec.aviation.piloting,rec.aviation.owning,rec.aviation.student
"Jim Burns" wrote in message
lengthwise.
may work better.
I think he may be missing the part where you use only 1/2 of the pipe?
Jim in NC
Old April 29th 06, 03:25 PM posted to rec.aviation.piloting,rec.aviation.owning,rec.aviation.student
On Sun, 9 Apr 2006 09:06:54 -0700, "RST Engineering"
with simple tools.
And you glue the edges or run a bolt thru both diameters? maybe a 1/2"
above ground level? - Mike
Have you created anything "home-made" for your plane? (or a low cost alternative?) Andy Piloting 69 April 29th 06 03:25 PM
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 12:56 AM
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 02:39 AM
Naval Air Refueling Needs Deferred in Air Force Tanker Plan Henry J Cobb Military Aviation 47 May 22nd 04 03:36 AM
Conspiracy Theorists (amusing) Grantland Military Aviation 1 October 2nd 03 12:17 AM
