My weird sink drain
Old April 12th 06, 10:07 AM posted to rec.aviation.piloting
Default My weird sink drain
Improper vent installation.
"AES" wrote in message
| This is totally OT for this group -- except the group
contains a lot of
| obviously clever people who are professionally interested
in aerodynamic
| and fluid flows and pressures, pipes, valves, and the
like, and maybe
| someone will be entertained by the following odd bathroom
sink behavior.
| Our newly remodeled bathroom has a circular glass
above-counter sink
| like a hemispherical glass salad bowl, about 18" in
diameter at the top
| and 7" deep, with a push down-pop up drain plug in the
bottom center,
| and a pretty high capacity faucet above it. Standard
elbow fitting and
| drain pipe going into the wall underneath the sink and
counter top.
| With the drain open, turn the faucet on full force: water
gets dumped
| into the sink considerable faster than it can drain out
and the water
| level in the sink rises rapidly up to the rim, on the
verge of
| overflowing, in 20 or 30 seconds.
| At the last second turn the faucet part way off -- down to
roughly 50%
| of full flow, more or less -- then trim the flow until
inflow rate just
| equals outflow, so the water level stays just 1/4 inch or
so below the
| rim. Then leave it in this steady-state condition, and
wait.
| For approximately *eight minutes* (by the watch) the
resulting situation
| remains perfectly stable, with water level hovering just
below the
| overflow point. Then, all of sudden, water level starts
dropping.
| Turn faucet back up to full flow. Water level continues
dropping, keeps
| dropping faster in fact, until sink is essentially empty,
and the full
| force input that initially caused the sink to fill now
roars down the
| drain with only 1/2' or so of water swirling around the
drain in the
| bottom. This continues as long as I want to watch.
| This doesn't seem to result from just blowing some
temporary clog out of
| the drain: I've repeated it three times, several hours
apart, with
| essentially identical behavior.
| I'm at a loss to explain how it happens, except to
hypothesize that
| maybe there's some point underground and quite a ways
further down the
| drain where the drain pipe has a long slow rise, then a
drop, and in
| some way the initial slower flow has to fill the rising
section until a
| siphon action gets going over the top?
| That doesn't really sound persuasive, however. Anyone
have any other
| ideas?
Old April 12th 06, 09:16 PM posted to rec.aviation.piloting
"Jim Macklin" wrote in message
news:Hs3%f.3012$8q.1738@dukeread08...
Good chance that is the case.
The vent is supposed to be in a vertical run of pipe, not in the horizontal,
and it is allowing water to have to pull the full cross sectional area of
pipe, without air replacing it, and water flowing in the bottom.
Jim in NC
Old April 12th 06, 10:29 PM posted to rec.aviation.piloting
I think a lot of people are going to Home Depot or Lowes and
doing their own plumbing and not following CODE. A
qualified plumber can tell pretty quickly what the problem
is, but a fix can involve considerable re-work if new vent
pipes must be run.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Morgans" wrote in message
| "Jim Macklin" wrote
in message
in the horizontal,
sectional area of
bottom.
| Jim in NC
Old April 12th 06, 10:38 PM posted to rec.aviation.piloting
pipes must be run.
Fortunately, a popup kind of vent is now available and legal (in most cases)
and the venting can be had with a minimum or "surgery."
You are right about the non-code bit, and also would be surprised at what
does pass, even when it is inspected.
Jim in NC
Old April 13th 06, 03:48 AM posted to rec.aviation.piloting
Morgans wrote: some stuff about venting.
I'd believe that is the case.
I once had an old, old, oooold house with a kitchen sink that didn't
have a vent. And it was a BIG sink. When you pull the plug on that
granny, it took the wash rag right with it, and me with both feet in
the sink pulling back! The whole sink drained in only 3 or 4 seconds,
and gurgled for a while after that.
Quick drain mess. dlevy Owning 10 October 17th 05 01:55 AM
Spider in Archer Sump Drain Bob Chilcoat Owning 3 June 29th 05 10:29 PM
Rounding a turnpoint in sink CV Soaring 13 July 22nd 04 05:27 PM
sump drain cleaning Mike Noel Owning 15 August 15th 03 02:41 AM
Across Nevada and Part Way Back (long) Marry Daniel or David Grah Soaring 18 July 30th 03 08:52 PM
