Jim Macklin wrote:
Instrument approaches are published for Class B,C,D and E airspace. An instrument approach requires controlled airspace and traffic separation. Class G is uncontrolled and although there may be a Class G airport, the instrument approach is conducted in the Class E over laid above the Class G. At uncontrolled airports instrument approaches are typically not contained entirely within controlled airspace. Check some of them out against a sectional and that will become apparent. Where the feds considered it essential to have the entire procedure contained within controlled airspace, they establish a Class E surface area. Class E surface areas are unusual. |
Transition areas at 700 feet, that means that VFR traffic
may be below a ceiling, true. But IAP are begun and conducted in Class E (or higher) airspace. If a pilot is not allowed by some company ops manual to cancel IFR [that would not be an FAA approved 135 manual, 135 does require a flight plan-VFR or IFR or other flight locating procedure]. If approaching an airport that is Class G at the surface, use a back-up radio to monitor CTAF and you can expect ATC to issue a clearance like this... Cleared for the approach, frequency change approved to CTAF, report cancellation [exact phraseology will vary]. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Sam Spade" wrote in message news:bTt%f.14159$bm6.11550@fed1read04... | Jim Macklin wrote: | | Instrument approaches are published for Class B,C,D and E | airspace. An instrument approach requires controlled | airspace and traffic separation. Class G is uncontrolled | and although there may be a Class G airport, the instrument | approach is conducted in the Class E over laid above the | Class G. | | | At uncontrolled airports instrument approaches are typically not | contained entirely within controlled airspace. Check some of them out | against a sectional and that will become apparent. | | Where the feds considered it essential to have the entire procedure | contained within controlled airspace, they establish a Class E surface | area. Class E surface areas are unusual. |
Circle to land question | A Lieberman | Instrument Flight Rules | 33 | May 24th 05 04:22 AM |
Confused about great circle navigation | xerj | Piloting | 7 | July 10th 04 05:38 PM |
R in a Circle (Airport Surveillance Radar) on VFR charts | Jeff Saylor | Piloting | 66 | May 12th 04 04:05 PM |
Defensive circle | Dave Eadsforth | Military Aviation | 23 | October 9th 03 06:13 PM |
NACO charts - why have a reference circle? | Bob Gardner | Instrument Flight Rules | 5 | September 6th 03 01:15 PM |
