![]() On Mon, 07 Jun 2004 02:30:39 GMT, "Richard Kaplan" wrote: "Roy Smith" wrote in message ... I seem to remember there used to be wording to the effect that an ICC/IPC needed to include a "representative sample" of the PTS checkride tasks. I can't remember if that was in the PTS itself or part 61/91 That wording is in 61.57(d). If the PTS is advisory and not binding, then the CFII's discretion will not have been significantly hampered. The current FAR 61,57(d) was last revised in 1997. The change 2 of the current PTS became effective in March 1999. AFS 640, the branch of the FAA that sets training policy, told me during the last examiner recertification seminar that the PTS is binding, and the task table provided within sets the minimum areas of operation required to complete an IPC. The term "representative tasks" are not at the descretion of the CFI, but are the tasks already set out and dictated by the task table. Nothing has changed with the upcomming change of the task table except that the tasks have been reduced, not increased. Don't take my word for it, call Oak City if you like, but don't hide your head in the sand and say it isn't so out of wishful thinking. To say that a Practical test STANDARD is not binding is laughable. Read the top of the current task table. It specifically states which tasks are required and MUST be tested during an IPC. You just never read it before. |
"Bill Zaleski" wrote in message
... the current PTS became effective in March 1999. AFS 640, the branch of the FAA that sets training policy, told me during the last examiner recertification seminar that the PTS is binding, and the task table Bill, The question of whether the PTS is legally binding upon a CFII is a bit more complex than this, as is often the case for areas where law and administrative regulations overlap. Your answer is sort of like saying you called a specific division of the IRS for a ruling on a complex taxation and that gave you a definitive answer. Actually, getting a definitive answer on federal tax regulations is quite complex and often has gray areas until a court reaches a final decision. Sometimes courts even give different answers in different districts around the country. It is very clear that the Advanced ATD concept was introduced after the 1999 PTS and that the Advanced ATD was intended for completing a full IPC. Yet if the PTS is considered to be legally binding, the Advanced ATD cannot be used for an IPC because a literal interpretation of the PTS requires landing out of an approach for an IPC, yet no Advanced ATD and no FTD is approved for landings. Thus if the PTS is legally binding then a huge percentage of piston IPCs done at virtually every major simulator center in the past 5 years are invalid. And if the PTS is legally binding then the whole concept of approving the Advanced ATD is inconsistent within the FAA's regulatory framework. I think the best answer is that there are some unclear or gray areas here which need to be resolved. Saying the PTS is obviously legally binding rather than advisory is like saying the AIM is obviously legally binding. Do you believe items in the AIM are advisory or binding? -------------------- Richard Kaplan, CFII www.flyimc.com |
![]() Do you believe items in the AIM are advisory or binding? They are advisory until there is an accident. Then they were binding. I say this tongue in cheek, but it does seem to be the FAA way. Jose -- (for Email, make the obvious changes in my address) |
"Teacherjh" wrote in message
... They are advisory until there is an accident. Then they were binding. OK, then let me ask a question which is now extremely appropriate to this thread. Suppose I am flying a real circling approach to minimums at an uncontrolled field and the only way I can safely comply with the circling visibility and runway distance requirements is by flying a non-standard pattern. Is it OK to consider the AIM advisory only in this case? -------------------- Richard Kaplan, CFII www.flyimc.com |
On Mon, 07 Jun 2004 22:16:55 GMT, "Richard Kaplan"
wrote: "Teacherjh" wrote in message ... They are advisory until there is an accident. Then they were binding. OK, then let me ask a question which is now extremely appropriate to this thread. Suppose I am flying a real circling approach to minimums at an uncontrolled field and the only way I can safely comply with the circling visibility and runway distance requirements is by flying a non-standard pattern. Is it OK to consider the AIM advisory only in this case? -------------------- Richard Kaplan, CFII www.flyimc.com What do you mean by "non-standard pattern"? Outside of any circling restrictions placed on the approach chart, there are no restrictions to type of pattern or direction, as long as you stay within circling visibility radius. Left/right traffic is irrelevant. You can circle the field multiple times in both directions, if you really want to. |
![]() "Bill Zaleski" wrote in message ... On Mon, 07 Jun 2004 22:16:55 GMT, "Richard Kaplan" What do you mean by "non-standard pattern"? Outside of any circling restrictions placed on the approach chart, there are no restrictions to type of pattern or direction, as long as you stay within circling visibility radius. Left/right traffic is irrelevant. You can circle the field multiple times in both directions, if you really want to. From AIM 4-3-4 -- Is this regulatory or advisory? c. Preparatory to landing at an airport without a control tower, or when the control tower is not in operation, pilots should concern themselves with the indicator for the approach end of the runway to be used. When approaching for landing, all turns must be made to the left unless a traffic pattern indicator indicates that turns should be made to the right. If the pilot will mentally enlarge the indicator for the runway to be used, the base and final approach legs of the traffic pattern to be flown immediately become apparent. Similar treatment of the indicator at the departure end of the runway will clearly indicate the direction of turn after takeoff. -------------------- Richard Kaplan, CFII www.flyimc.com |
On Tue, 08 Jun 2004 03:20:51 GMT, "Richard Kaplan"
wrote: "Bill Zaleski" wrote in message .. . On Mon, 07 Jun 2004 22:16:55 GMT, "Richard Kaplan" What do you mean by "non-standard pattern"? Outside of any circling restrictions placed on the approach chart, there are no restrictions to type of pattern or direction, as long as you stay within circling visibility radius. Left/right traffic is irrelevant. You can circle the field multiple times in both directions, if you really want to. From AIM 4-3-4 -- Is this regulatory or advisory? c. Preparatory to landing at an airport without a control tower, or when the control tower is not in operation, pilots should concern themselves with the indicator for the approach end of the runway to be used. When approaching for landing, all turns must be made to the left unless a traffic pattern indicator indicates that turns should be made to the right. If the pilot will mentally enlarge the indicator for the runway to be used, the base and final approach legs of the traffic pattern to be flown immediately become apparent. Similar treatment of the indicator at the departure end of the runway will clearly indicate the direction of turn after takeoff. -------------------- Richard Kaplan, CFII www.flyimc.com This does not apply to IFR arrivals desiring to circle in instrument conditions. The approach chart limitations/notations are the only limitation. What are you teaching your students? You should read the TERPS. |
That is like saying that "Speed Limits are advisory, unless a cop is
around".... Come to think of it, I guess they are! Rich Teacherjh wrote: Do you believe items in the AIM are advisory or binding? They are advisory until there is an accident. Then they were binding. I say this tongue in cheek, but it does seem to be the FAA way. Jose |
![]() "Rich" wrote in message ... That is like saying that "Speed Limits are advisory, unless a cop is around".... Come to think of it, I guess they are! In some states, speed limits _were_ advisory (in the 30's and so)...until they realized what a treasure trove they could be. |
On Mon, 07 Jun 2004 11:48:39 GMT, "Richard Kaplan"
wrote: "Bill Zaleski" wrote in message .. . the current PTS became effective in March 1999. AFS 640, the branch of the FAA that sets training policy, told me during the last examiner recertification seminar that the PTS is binding, and the task table Bill, The question of whether the PTS is legally binding upon a CFII is a bit more complex than this, as is often the case for areas where law and administrative regulations overlap. Your answer is sort of like saying you called a specific division of the IRS for a ruling on a complex taxation and that gave you a definitive answer. Actually, getting a definitive answer on federal tax regulations is quite complex and often has gray areas until a court reaches a final decision. Sometimes courts even give different answers in different districts around the country. It is very clear that the Advanced ATD concept was introduced after the 1999 PTS and that the Advanced ATD was intended for completing a full IPC. Yet if the PTS is considered to be legally binding, the Advanced ATD cannot be used for an IPC because a literal interpretation of the PTS requires landing out of an approach for an IPC, yet no Advanced ATD and no FTD is approved for landings. Thus if the PTS is legally binding then a huge percentage of piston IPCs done at virtually every major simulator center in the past 5 years are invalid. And if the PTS is legally binding then the whole concept of approving the Advanced ATD is inconsistent within the FAA's regulatory framework. I think the best answer is that there are some unclear or gray areas here which need to be resolved. Saying the PTS is obviously legally binding rather than advisory is like saying the AIM is obviously legally binding. Do you believe items in the AIM are advisory or binding? -------------------- Richard Kaplan, CFII www.flyimc.com So, in effect, you are saying that those who wrote the PTS are not in a position to provide accurate information on it's use, validity, or legality. Again, laughable. Who do you plan to go to for any meaningful guidance? You've already said that the FSDO's don't know how to handle queries on this issue. I recall giving you information on the use of the FTD without an instructor present for currency that you were steadfast against until the simulator branch confirmed to you what you didn't want to hear. Time to use common sense here. It wouldn't be called an STANDARD (PTS). if it wasn't a standard. Yup, it's binding. Call 'em up like you finally did last time. |
Logging approaches | Ron Garrison | Instrument Flight Rules | 109 | March 2nd 04 05:54 PM |
CFI logging instrument time | Barry | Instrument Flight Rules | 21 | November 11th 03 12:23 AM |
Instrument Rating Ground School at Central Jersey Regional (47N) | john price | Instrument Flight Rules | 0 | October 29th 03 12:56 PM |
Instrument Rating Ground School at Central Jersey Regional (47N) | john price | Instrument Flight Rules | 0 | October 12th 03 12:25 PM |
Use of hand-held GPS on FAA check ride | Barry | Instrument Flight Rules | 1 | August 9th 03 09:25 PM |
