![]() " Considering that Lycoming and Continental have BILLIONS (TRILLIONS ?? ) of hours flying, it's not surprising that they've killed more pilots. What's also amusing is people that can't correlate data but shoot their mouth off anyway. -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO Oh yes... thank you, I see now, your data is much more precise than mine (BILLIONS and TRILLIONS). Oh, hang on! you have no data either. Perhaps you should correlate some data and then proceed to shoot your mouth off. While we are on the subject, Morgans advised that two LSA aircraft with Rotax engines crashed after engine failures and even though they were probably the ultralight two stroke Rotax engines, he will never fly any LSA at all and particularly with any Rotax engine including the ultra reliable four stroke 912 or the unrelated Jabiru engine. There is simply no comparison between a two stroke Rotax a four stroke Rotax and a Jabiru, please, are we really that stupid to bundle all LSA aircraft and engines into one basket because of two crashes? By the way, a friend of mine was flying a Russian utility plane with an M14P radial engine when it threw a rod/piston and the engine failed. As a result, you will not find me flying an all metal GA aircraft, particularly Cessna's and Pipers with piston engines made by Lycomming or Continental! Bob. |
![]() "Bob O'Rilley" wrote in message ... " Considering that Lycoming and Continental have BILLIONS (TRILLIONS ?? ) of hours flying, it's not surprising that they've killed more pilots. What's also amusing is people that can't correlate data but shoot their mouth off anyway. -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO Oh yes... thank you, I see now, your data is much more precise than mine (BILLIONS and TRILLIONS). Oh, hang on! you have no data either. Perhaps you should correlate some data and then proceed to shoot your mouth off. Thanks you for aptly demonstrating you have no clue what you're blabbering about. While we are on the subject, Morgans advised that two LSA aircraft with Rotax engines crashed after engine failures and even though they were probably the ultralight two stroke Rotax engines, he will never fly any LSA at all and particularly with any Rotax engine including the ultra reliable four stroke 912 or the unrelated Jabiru engine. There is simply no comparison between a two stroke Rotax a four stroke Rotax and a Jabiru, please, are we really that stupid to bundle all LSA aircraft and engines into one basket because of two crashes? By the way, a friend of mine was flying a Russian utility plane with an M14P radial engine when it threw a rod/piston and the engine failed. As a result, you will not find me flying an all metal GA aircraft, particularly Cessna's and Pipers with piston engines made by Lycomming or Continental! Bob. Bob = Clueless |
![]() "Bob O'Rilley" wrote While we are on the subject, Morgans advised that two LSA aircraft with Rotax engines crashed after engine failures and even though they were probably the ultralight two stroke Rotax engines, he will never fly any LSA at all and particularly with any Rotax engine including the ultra reliable four stroke 912 or the unrelated Jabiru engine. Thanks for proving that you are not only an idiot, but a lazy idiot. If you had taken two minutes to do a little research, you would have found that both crashes were 4 stroke Rotaxes. The first rule of getting out of a hole, is to stop digging, and take your foot out of your mouth, also. -- Jim in NC |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
