#11
Hi Kent, Long time no talk. You still doing balance work? Seemed to be a whirl mode much like that described for a radial with a too-loose front propshaft bearing. This was with the 3 cyl Suzuki, an engine with a natural wobble, again much like the radial. The PSRU was a cantilever upper axle type, so just a little excess freeplay in the bearing setup was enough to set it whirling at high power. The torsional amplitude pulsed at about 2 hertz on the o-scope display. Took awhile to realize what we were had. You could hear it in the prop noise and see the whirl at night if you lit the prop disk with a flood. Didn't explore it much as we had other stuff on the front burner. Just got rid of the freeplay. Dan |
Ben,
I wasn't wrong about the front journal, it's just a matter of semantics. When I said the front journal, I meant the one from which the drive pulley is attached, obviously. Even if this is the rear journal on the engine as mounted in the car, it is obviously the frontmost journal when a redrive and prop is bolted to it. And you are quite wrong about poly-v belts. They can indeed take upwards of 1000hp. I'm looking right now at the Hutchinson design manual and there are belts available that will take 800 kilowatt, which is 1072 horsepower. Also significant is the design rpm and duty cycle, both of which are very high. Cog belts are inherently inferior because the ribs acting against the pulley sprockets produce more heat. They should only be used where you need a synchronicity between the drive and the driven device. This is not the case with a prop -- it does not need to be synchronized. (Incidentally, "cog" is not even the correct terminology for these belts, they are called synchronous belts. Cog belts are actually V-belts, with ribs on their inside surface for heat dissipation, like fins on cylinder heads.) Someone mentioned 200 hours for synchronous belts, which is nowhere near what a properly desgned poly-v belt will provide. Why are the "cog" belts so popular then? Who knows, but being popular does not make it sound engneering. Personally I would not use any commercially available redrive, gearbox or belt, except for the ones offered by Rotax and Powersport, because they are the only vendors who have actually done scientific torsional vibration testing and measurement and have given prop moment of inertia ranges that are known to be safe. Regards, Gordon. "stol" wrote in message ups.com... Chain drives have the same effect. Belt and chain drives do impose side loads on the front crankshaft journal, however, so that is a negative point. Another issue is packaging ///////////////////////////////////////////////////////////////////////////////////////////////////////////////////// Well written explanation but this is incorrect. The sideload is imposed on the rearmain journal of the crank, not the front one. Most redrives that use the cog belt also incorporate an idler bearing outboard of the lower sprocket, that prevents the sideload forces on the crank. Also I think a multivee belt will not transfer 1000 hp, I don't think it would evem work on my 330 hp+ auto engine powered plane. I will stick with my cog belt, thank you. Ben www.haaspowerair.com |
"Gordon Arnaut" wrote Personally I would not use any commercially available redrive, gearbox or belt, except for the ones offered by Rotax and Powersport, because they are the only vendors who have actually done scientific torsional vibration testing and measurement and have given prop moment of inertia ranges that are known to be safe. I remember you, now. I replied with BULL**** back then, and I'll do the same, now. To say that nobody except Rotax and Powersport have tested their drives is bull****, and if I were a drive manufacture that had, I would sue you for slander. Go back into your hole, where you have been for the past 10 or so months. We don't need know-it-all like you, spouting off. -- Jim in NC P.S. Go ahead, be true to form, and make some personal remarks about me now. I can take it. I consider the source, and take it for what it is worth. Zero. |
Hi Dan,
Yes, I'm still busy. Interesting example of the Suzuki. I lost your email in my last CPU crash. And occasionally have wondered what you was up to. I'll write you later. Btw, I'd to take this opportunity make an announcement to others in this thread. I've hung out on RAH since ohh maybe 1998-99 and I still check in a couple times per week. Anymore though, when I open the cellar door I hear too much scurrying to want to come down the steps. Last time I tried to contribute a little benefit of my experience about balancing and vibration to a thread, some people quickly turned it personal, inferred me and my friends were crooks and pieces of ****, or P.O.S. I think was their term. Others here supported them. In fact some same people contributed to this recent thread! They know who they are. . F Amateurs. Go Get a job. Kent Felkins "Dan Horton" wrote in message oups.com... Hi Kent, Long time no talk. You still doing balance work? Seemed to be a whirl mode much like that described for a radial with a too-loose front propshaft bearing. This was with the 3 cyl Suzuki, an engine with a natural wobble, again much like the radial. The PSRU was a cantilever upper axle type, so just a little excess freeplay in the bearing setup was enough to set it whirling at high power. The torsional amplitude pulsed at about 2 hertz on the o-scope display. Took awhile to realize what we were had. You could hear it in the prop noise and see the whirl at night if you lit the prop disk with a flood. Didn't explore it much as we had other stuff on the front burner. Just got rid of the freeplay. Dan *** Posted via a free Usenet account from http://www.teranews.com *** |
Gordon Arnaut wrote:
However, the prop is a spring mass that acts to amplify the excitations that comes from other sources... No. Blade root bending within the plane of rotation can be modeled as equivalent to a shaft stiffness. The prop itself has no special ability to excite anything. And yes, it is the inertia produced by the centrifugal force, not the centrifugal force itself .... Centrifugal force has nothing to do with it, period. However I do not agree that the problem frequency will necessarily have to fall within the operating range. Stiffness of the shaft will be largely a function of its slenderness ratio, so using a material with a high modulus, perhaps carbon, and a large diameter, could produce a shaft that is light yet stiff enough to do the trick. Overall system stiffness is cumulative. Every shaft or shaft equivalent (crank twist, belt or chain elongation, flexible structure between sprockets, blade root bending, whatever) contributes so that the overall system is somewhat less than infinitely stiff. Even with a hell-for-stiff carbon shaft I don't think you can push F1 up above the operating range. You'll need an F1 above 220 hz to work with a 5500 RPM 4-cyl, or 300 hz for a 6-cyl with a 5000 RPM operating range. The current average for short "hard" systems (think Blanton style) is about 50 hz. Good luck. Dan |
Dan,
The prop can indeed contribute excitations, if it is first excited to go into resonance itself. As the prop oscillations grow in amplitude it will overstress other components that are not as flexible, such as the crank or gearbox. This can happen to a non-counterweighted Lycoming with certain CS props if you operate it continuously between 2050 and 2250 rpm, or thereabouts. What happens is the prop has a resonant frequency at that rpm range, which means it will go into resonance and its oscillations will continue to grow. But long before the prop breaks, the crank will break, because it is far less flexible. Without the prop, the engine has no problem running all day at that rpm, so it is the prop that is contributing the excitations. Further proof is that the lighter MT prop is STC'd to eliminate the placarded operating limitation. So the prop does indeed contribute to the excitation side of the equation, if only in a roundabout way. Of course the full explanation is more complex because when you combine a prop that has its particular resonant frequency and and and engine with a different set of resonant frequencies, what you get is a whole new set of resonant frequencies. By bolting these two items together, you now have a new system with its own vibrational characteristics. And if you add a gearbox too, then you get a whole new set of resonant frequency, because now you have a new system again. And here again the g4earbox itself can now also contribute to the excitation side of equation in the same way as the prop -- by going into resonance and either breaking itself or something else in the chain. An interesting approach has been to use a spring-loaded clutch disk between the crank and the gearbox -- this is used in the Ross gearbox for example. Most people assume that this works because the springs compress to "damp"some of the torsional vibration, but that's not how it works. It works because the springs have a preload of a certain force and will compress only when torsional oscillations reach a certain amplitude. What happens then is not some kind of damping, but the fact that as soon the springs are compressed the system now instantly has more springiness, which means its resonant frequencies are now completely different from when the springs were locked up solidly. You have in essence a drivetrain system with variable resonant characteristics. This means that as soon as the springs kick in, the system is no longer in resonance because its resonant frequencies are now quite a bit lower, due to the added flexibility of the entire system. So the oscillations stop. You yourself alluded to this in your remarks about overall system stiffness. This is illustrative of how the problem needs to be approached from a drivetrain system perspective -- because each piece that you attach to an engine will change the system as a whole. It also shows that each piece can contribute excitations if any constituent piece is allowed to go into resonance. "Dan Horton" wrote in message ups.com... Gordon Arnaut wrote: However, the prop is a spring mass that acts to amplify the excitations that comes from other sources... No. Blade root bending within the plane of rotation can be modeled as equivalent to a shaft stiffness. The prop itself has no special ability to excite anything. And yes, it is the inertia produced by the centrifugal force, not the centrifugal force itself .... Centrifugal force has nothing to do with it, period. However I do not agree that the problem frequency will necessarily have to fall within the operating range. Stiffness of the shaft will be largely a function of its slenderness ratio, so using a material with a high modulus, perhaps carbon, and a large diameter, could produce a shaft that is light yet stiff enough to do the trick. Overall system stiffness is cumulative. Every shaft or shaft equivalent (crank twist, belt or chain elongation, flexible structure between sprockets, blade root bending, whatever) contributes so that the overall system is somewhat less than infinitely stiff. Even with a hell-for-stiff carbon shaft I don't think you can push F1 up above the operating range. You'll need an F1 above 220 hz to work with a 5500 RPM 4-cyl, or 300 hz for a 6-cyl with a 5000 RPM operating range. The current average for short "hard" systems (think Blanton style) is about 50 hz. Good luck. Dan |
Dan Horton wrote:
Gordon Arnaut wrote: However, the prop is a spring mass that acts to amplify the excitations that comes from other sources... No. Blade root bending within the plane of rotation can be modeled as equivalent to a shaft stiffness. The prop itself has no special ability to excite anything. And yes, it is the inertia produced by the centrifugal force, not the centrifugal force itself .... Centrifugal force has nothing to do with it, period. According to Ker Wilson, prop flutter has no real impact on torsional vibration. He could be wrong, but he devoted more than a half century to the subject. Blade passing frequency, however, apparently does come into play in some systems. So does whirl, but that isn't the internet topic of the year. Centrifugal force is a result of the inertia, not the other way around. At least in this reality. Not only does the crank/rod/piston system have multiple resonant torsional frequencies, they move during operation. While we're at it, it sure would be handy to see a list of V8 crankshafts with a critical lower than the idle rpm gas excitation forces, since that is apparently often the case. Charles |
"Gordon Arnaut" wrote This means that as soon as the springs kick in, the system is no longer in resonance because its resonant frequencies are now quite a bit lower, due to the added flexibility of the entire system. So the oscillations stop. You yourself alluded to this in your remarks about overall system stiffness. For pete's sake, give it a rest. Your incomplete knowledge is showing in spades. -- Jim in NC |
Charles,
Actually there is more than one reality when it comes to centrifugal force, namely the reactive centrifugal force and the fictitious centrifugal force -- depending on what you want to use as your reference frame. But this is quickly descending into ridiculous semantics. My original point was that if you have a flywheel with enough inertia, it will be an effective restraining force to act against excitations that would otherwise produce vibration. Naturally, higher moment of inertia in a rotating object must necessitate a higher centrifugal force. Saying that one causes the other is quite meaningless, in a chicken and egg kind of way. Regards, Gordon. "Charles Vincent" wrote in message et... Dan Horton wrote: Gordon Arnaut wrote: However, the prop is a spring mass that acts to amplify the excitations that comes from other sources... No. Blade root bending within the plane of rotation can be modeled as equivalent to a shaft stiffness. The prop itself has no special ability to excite anything. And yes, it is the inertia produced by the centrifugal force, not the centrifugal force itself .... Centrifugal force has nothing to do with it, period. According to Ker Wilson, prop flutter has no real impact on torsional vibration. He could be wrong, but he devoted more than a half century to the subject. Blade passing frequency, however, apparently does come into play in some systems. So does whirl, but that isn't the internet topic of the year. Centrifugal force is a result of the inertia, not the other way around. At least in this reality. Not only does the crank/rod/piston system have multiple resonant torsional frequencies, they move during operation. While we're at it, it sure would be handy to see a list of V8 crankshafts with a critical lower than the idle rpm gas excitation forces, since that is apparently often the case. Charles |
Hello Charles, According to Ker Wilson, prop flutter has no real impact on torsional vibration. He could be wrong, but he devoted more than a half century to the subject. Blade passing frequency, however, apparently does come into play in some systems. So does whirl, but that isn't the internet topic of the year. Ahh, thank you, appreciate the confirmation. Lucky dog, wish I had my own copy. I have to beg my local librarian to get it from the UA library. Dan |
| Thread Tools | |
| Display Modes | |
| PSRU design advantages | ADK | Home Built | 74 | April 12th 06 10:31 PM |
| light twins? | Bellsouth News Server | Home Built | 83 | August 12th 05 03:56 AM |
| Aircraft engine certification FAR's | Corky Scott | Home Built | 4 | July 25th 03 07:46 PM |
