Toyota (aluminum) Diesel 1.4 D-4D ...89 bhp
Old April 14th 06, 11:16 PM posted to rec.aviation.homebuilt
Default Toyota (aluminum) Diesel 1.4 D-4D ...89 bhp
Hmm... I have no problems with the site. On the other hand, I am linked to
it from the Europe.
JP
"Montblack" kirjoitti
("JP" wrote)
Look http://www.geocities.com/plane_diesel/index.html
Sorry, this GeoCities site is currently unavailable.
The GeoCities web site you were trying to view has temporarily exceeded
its data transfer limit. Please try again later.
Are you the site owner? Avoid service interruptions in the future by
increasing your data transfer limit! Find out how.
(Hope it didn't overload because of us. g)
Montblack
Old April 15th 06, 02:54 AM posted to rec.aviation.homebuilt
("JP" wrote)
it from the Europe.
It's up again.
Found the weight of the engine: 99kg for the Toyota, but that includes some
stuff.
http://www.geocities.com/plane_diesel/index2.html
"Toyota Yaris England or Echo Australia ECHO Philippines or Vitz Japan
1.4ltr D-4D
The 66mpg Toyota Yaris D-4D. 170Nm is realised at only 2,000rpm,... Power
output is modest at 74bhp,.the block is aluminium, making it one of the
lightest diesels on the market.
Both the cylinder head, block and air-air intercooler are made of aluminium
alloy. As another clever way to save space and weight, the Toyota
turbocharger is completely integrated into the exhaust manifold and the
alloy intake manifold is also integrated into the cylinder head. in a
weight of just 99kg for the 1.4 D-4D engine.
The normally aspirated 1.3-litre engine is a version of the Yaris with
different state of tune to pump out 90 hp. It also features VVT-i continuous
variable valve timing although Daihatsu called it "DVVT" instead (D for
Daihatsu?)."
Montblack
Question about Alodine 1201 Andrew Sarangan Home Built 20 April 11th 06 02:31 PM
2-stroke diesel is the (near) future? Max Kallio Home Built 134 July 18th 05 01:39 AM
2-stroke diesel is the (near) future? Max Kallio Rotorcraft 123 July 18th 05 01:39 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 04:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 07:24 AM
