Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
ICOM A23 Transformer Specs
Old April 15th 06, 07:53 PM posted to rec.aviation.misc,rec.aviation.products,rec.aviation.piloting
Default ICOM A23 Transformer Specs
Would someone please give me the specs for the AC-DC transformer for
the ICOM A-23? I've misplaced mine and ICOM wants $40 for a
replacement. I can probably do better with a generic one from Radio
Shack. I need to know the polarity, DC voltage, and amps.
Thanks
(Sorry for the cross-post to rec.aviation.piloting, but that group
seems more active than the rest.)
Old April 15th 06, 08:07 PM posted to rec.aviation.misc,rec.aviation.products,rec.aviation.piloting
Mine says:
Input: 120VAC 60Hz 4.5W
Output: 12VDC 200 mA
Class 2 Transformer
Thanks
Old April 15th 06, 08:10 PM posted to rec.aviation.misc,rec.aviation.products,rec.aviation.piloting
Sorry, forgot the polarity:
Outer ring -, Inner ring +
"Jeremy Lew" wrote in message
Mine says:
Class 2 Transformer
Thanks
Old April 15th 06, 08:23 PM posted to rec.aviation.misc,rec.aviation.products,rec.aviation.piloting
Thanks!
Old April 15th 06, 08:42 PM posted to rec.aviation.misc
"rps" wrote:
Thanks!
And these little 'wall warts' will work fine, I use a bunch here
on my many hand held ham trancseivers...just make sure that the
voltage is close and that the polarity is right (and the current
at or above specs)
-Gord.
(use gordon in email)
Old April 15th 06, 10:32 PM posted to rec.aviation.misc
Gord Beaman wrote:
"rps" wrote:
Thanks!
at or above specs)
I've always wondered why equipment manufacturers don't put a full wave
bridge (4 diodes) in the battery circuit so it doesn't matter how you
insert the batteries (or the polarity of a charger brick).
Old April 15th 06, 11:26 PM posted to rec.aviation.misc,rec.aviation.products,rec.aviation.piloting
says...
You also need the size - these things come in a million different
sizes. The Outside Diameter on mine is 3.5mm.
GF
Old April 15th 06, 11:50 PM posted to rec.aviation.misc
Stubby wrote:
Gord Beaman wrote:
"rps" wrote:
Thanks!
at or above specs)
Gosh... That'd cost an extra 20c and might use around 1 sq cm
of board space. !
_________________________________________
Usenet Zone Free Binaries Usenet Server
More than 140,000 groups
Unlimited download
http://www.usenetzone.com to open account
Old April 16th 06, 04:23 AM posted to rec.aviation.misc,rec.aviation.products,rec.aviation.piloting
"Greg Farris" wrote in message
says...
GF
Look here. Cheep Cheep!
http://www.hosfeltelectronics.com/
Old April 16th 06, 03:05 PM posted to rec.aviation.misc
Stubby wrote:
: I've always wondered why equipment manufacturers don't put a full wave
: bridge (4 diodes) in the battery circuit so it doesn't matter how you
: insert the batteries (or the polarity of a charger brick).
Voltage drop. Even low-voltage schottky diodes will drop 0.3-0.4V. That's
like throwing away 33% of your 1.2v battery capacity.
-Cory
* Cory Papenfuss, Ph.D., PPSEL-IA *
* Electrical Engineering *
Icom A6 Radio Registration Problem Clyde Torres Home Built 4 May 6th 05 12:21 PM
ICOM IC-A23 Sport Karl-Heinz Künzel Piloting 1 September 11th 04 06:43 PM
Need part number for Icom antenna jack Roy Smith Owning 2 March 17th 04 09:59 PM
Icom Boom Mike Kevin Neave Soaring 2 September 25th 03 09:39 AM
Icom CM-35 Desktop Battery Charger for Icom IC-A2 Radio A. Kay Aviation Marketplace 0 August 23rd 03 08:01 AM
