Roger wrote:
: If I fly without the wheelpants, I notice a few mph difference, and : the plane floats less on landing. : A Cherokee that floats? With aftermarket wingtips and VG's on it, a Cherokee actually floats quite a bit in ground-effect. At least up to the point where it mushes. -Cory -- ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Quite true, but then the concept of "floating" is relegated to any
approach speed above stall-speed. How much speed margin is included in the POH approach speed? Indeed, for a "slam-dunk" short-field approach, one hangs it on the prop with a minimal speed margin that gust factor allows. All I was trying to point out is that the (deserved) bad reputation of the PA-28 gliding like a refrigerator with power-off can be partially mitigated by the VG installation. As a representative datapoint, I fly the approach in my PA-28-180 at 80mph IAS with 2-notches. The book value says 85 mph (minus 2 x 3mph for the flaps) = 79mph. With that speed, I've got just a second or two of "finesse" to do at the flare before the energy is gone and it sinks on. At 75 mph it's a flare-drop-chunk one-motion. Given the VG's and aftermarket wingtips on it, that's pretty much book corrected for 5mph or so. Prior to the mods, coming in at 80mph with 2-notches had a pretty ugly sink rate associated with it. -Cory : I would think that still means the landing is too fast. With STOL : mods that lower the stall speed the landing speed would be adjusted to : meet the new stall speeds. : Float normally means too fast. If the mods change the characteristics : so that float is still there at the corrected speeds I'd have some : concern. : Typically it takes a while to get used to flying the proper speeds : after adding mods that reduce the stall speed and increase lift at low : speed. : Roger Halstead (K8RI & ARRL life member) : (N833R, S# CD-2 Worlds oldest Debonair) : www.rogerhalstead.com : : -Cory -- ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
On Mon, 17 Apr 2006 15:23:42 +0000 (UTC),
wrote: snip All I was trying to point out is that the (deserved) bad reputation of the PA-28 gliding like a refrigerator with power-off can be partially mitigated by the VG installation. snip Ever driven a 114 Commander? You'd think it was a refrigerator with the door open... TC |
On 04/17/06 15:11, wrote:
On Mon, 17 Apr 2006 15:23:42 +0000 (UTC), wrote: snip All I was trying to point out is that the (deserved) bad reputation of the PA-28 gliding like a refrigerator with power-off can be partially mitigated by the VG installation. snip Ever driven a 114 Commander? You'd think it was a refrigerator with the door open... so ... the interior light is on? ;-) TC -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
On Mon, 17 Apr 2006 15:22:47 -0700, Mark Hansen
wrote: On 04/17/06 15:11, wrote: On Mon, 17 Apr 2006 15:23:42 +0000 (UTC), wrote: snip All I was trying to point out is that the (deserved) bad reputation of the PA-28 gliding like a refrigerator with power-off can be partially mitigated by the VG installation. snip Ever driven a 114 Commander? You'd think it was a refrigerator with the door open... so ... the interior light is on? ;-) heh. was lucky enuff years back to have the opportunity to take a newer 114 for a test-hop after work. at the time was also familiar with/comfortable in constant-chord PA28's & 32's of just about every variety. less than 2 hours of fuel onboard plus a couple of guys from the prop shop that wanted to go along. wasn't particularly comfortable with the climbout, but the base-to-final rate of descent was a real eye-opener (rectum-clencher?). running out of rudder over the threshold irritated me slightly also. TC |
wrote: Quite true, but then the concept of "floating" is relegated to any approach speed above stall-speed. How much speed margin is included in the POH I always heard it used as referencing the plane not touching down when it should and all finals as opposed to approaches are normally flown above stall speed. If the final is normally flown at 1.3 Vso and the most of the speed bled off in the round out as the plane enters ground effect the touch down should be gentle. Think of it this way. As you go into the flare the plane should not start climbing again. The speed should bleed off so as the plane comes out of the round out pretty much level in ground effect. Then just above the runway the nose is raised slightly to finish slowing to the point where the wheels will settle onto the runway. approach speed? Indeed, for a "slam-dunk" short-field approach, one hangs it on the prop with a minimal speed margin that gust factor allows. Even a short field can be done with out a "slam dunk". Cherokees are very good at a nice touchdown, immediately lower the nose (after the mains are on), raise those mechanical flaps, get on the brakes and full up elevator and they will really stop short. All I was trying to point out is that the (deserved) bad reputation of the PA-28 gliding like a refrigerator with power-off can be partially mitigated by the VG installation. I've heard people joke about the steep glide, but this is the first I ever heard it referred to as having a bad reputation. Why would the PA-28 have a bad reputation for its glide ratio with power off. I put a bit over 300 hours on one and was quite comfortable with it. Many high performance singles have a faster rate of descent with a steeper final than the Cherokee. As a representative datapoint, I fly the approach in my PA-28-180 at 80mph IAS with 2-notches. The book value says 85 mph (minus 2 x 3mph for the flaps) = 79mph. That's faster than I land a Deb or Bonanza, but it is as I recall about what I used to fly final in the 180. OTOH Vso with only me and half fuel in the Deb is about 55 MPH. and that equates to a final at 71 MPH. Now that is *steep* and requires a fair amount of power. Engine out is quite a bit faster as at 71 MPH you don't have enough energy to flare. With that speed, I've got just a second or two of "finesse" to do at the flare before the energy is gone and it sinks on. At 75 mph it's a flare-drop-chunk one-motion. Given the VG's and aftermarket wingtips on it, that's pretty much book corrected for 5mph or so. Prior to the mods, coming in at 80mph with 2-notches had a pretty ugly sink rate associated with it. I never noticed that and I always used full flaps in both the Cherokee and the Deb.. It's what I was taught, it's what I was used to and it was just a matter of controlling the airspeed and initiating both the round out and flare at the right time. Actually the Deb with power off and full flaps at the proper speed is very much like landing a Cherokee 180 in the same configuration. With practice you can make a gentle touchdown and use very little runway. They have almost identical wing loading. However with the larger flaps on the Deb I can hit about 2200 FPM rate of descent if in a hurry. That does require a bit of a slip though.:-)) Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com -Cory : I would think that still means the landing is too fast. With STOL : mods that lower the stall speed the landing speed would be adjusted to : meet the new stall speeds. : Float normally means too fast. If the mods change the characteristics : so that float is still there at the corrected speeds I'd have some : concern. : Typically it takes a while to get used to flying the proper speeds : after adding mods that reduce the stall speed and increase lift at low : speed. : Roger Halstead (K8RI & ARRL life member) : (N833R, S# CD-2 Worlds oldest Debonair) : www.rogerhalstead.com : : -Cory |
Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 10:18 PM |
Why does a prop ice up so apparently readily? | Mike Rapoport | General Aviation | 3 | November 8th 05 02:52 PM |
Why does a prop ice up so apparently readily? | Mike Rapoport | Piloting | 2 | November 8th 05 02:52 PM |
Why does a prop ice up so apparently readily? | Mike Rapoport | Instrument Flight Rules | 2 | November 8th 05 02:52 PM |
IVO props... comments.. | Dave S | Home Built | 16 | December 6th 03 11:43 PM |
