Jim,
It is very remarkable you have been able to do this to your batteries for four years without damage. I wouldn't recommend it for large solar systems. However, for an in-flight use, where the pv is basically augmenting the battery supply a charge controller isn't needed. With longer term charging & sustaining an inexpensive controller is essential if you want to get the full life out of the batteries. Regarding your need for 250 more watts: You might want to do some math as it looks like you are right on with what you have now. PV's today are going for between $4 and $6 per watt, so your 250 W would cost you around $1,000 at the bottom end not including freight, mounting, and labor. So at $40/year savings it would take you the life of the PV to earn back your expense, not considering present dollar value or roi on the $1000 if you didn't spend it. Sounds like you planned your system very, very well! |
![]() "Go" wrote in message oups.com... However, for an in-flight use, where the pv is basically augmenting the battery supply a charge controller isn't needed. Until somebody forgets that there is no controller and the glider happens to spend a few days out of the trailer... I have ruined enough batteries from overcharging to have finally had the lesson forever drilled into my head; charge controllers are cheap and necessary. With longer term charging & sustaining an inexpensive controller is essential if you want to get the full life out of the batteries. I agree. Regards, Vaughn |
Good point.
Vaughn Simon wrote: Until somebody forgets that there is no controller and the glider happens to spend a few days out of the trailer... I have ruined enough batteries from overcharging to have finally had the lesson forever drilled into my head; charge controllers are cheap and necessary. |
SoLong Solar-Electric UAV 48 hour flight | Larry Dighera | Piloting | 6 | September 25th 16 08:01 PM |
Solar Airplane, Piccard&A-rabs | Jim Culp | Soaring | 1 | April 1st 05 03:27 AM |
Solar Powered Round The World Flight Planned For 2009 | Larry Dighera | Piloting | 7 | March 14th 05 07:36 AM |
Solar Powered Round The World Flight Planned For 2009 | Larry Dighera | Soaring | 7 | March 14th 05 07:36 AM |
Gliding electic flight - cells which one? | max christoffersen | Soaring | 1 | November 30th 03 09:06 PM |
