Skywise wrote in news:1245n0dkkfsst01
@corp.supernews.com: I had made passing mention recently about spotting a U2 aircraft cruising around southern California. Well, this past week I managed to get some good photographs of it and have put up a webpage about it. Turned out to be a NASA ER-2. http://www.skywise711.com/misc/ER2/ER2.html Brian On further consideration, this may indeed be a WB-57. I had looked up the B-57 on wikipedia, but all the pictures showed stubby clipped triangular wings. But someone else in another group provided this link, http://jsc-aircraft-ops.jsc.nasa.gov/wb57/ This shows the NASA WB-57's, and they do look alot like what I photographed, and nothing like the pics on Wikipedia. Going back to that article, I found mention that the USAF had ordered several of these planes but with modified 33 and later 37 meter wings. Much larger than the original 20 meter wings. Now, knowing that the plane has two engines would explain the split vapor trail seen in the first images. I had assumed this was just some sort of vortex effect causing the single exhaust of the ER-2 to split. Furthermore, looking at the enhanced image, the tail does bear a striking resemblence to the WB-57. The vertical fin starts ahead of the elevators like the WB-57 does, whereas the ER-2 has them both starting at about the same place. Wow. Learned something new. I was not even aware of the WB-57's. Now I have to redo my webpage. Brian -- http://www.skywise711.com - Lasers, Seismology, Astronomy, Skepticism Seismic FAQ: http://www.skywise711.com/SeismicFAQ/SeismicFAQ.html Quake "predictions": http://www.skywise711.com/quakes/EQDB/index.html Sed quis custodiet ipsos Custodes? |
NASA model uses thermals | Burt Compton - Marfa | Soaring | 10 | October 8th 05 03:24 PM |
What has NASA done for you? | BobGoFish | Piloting | 34 | August 9th 05 08:14 PM |
ASRS/ASAP reporting systems - how confidential? | Tim Epstein | Piloting | 7 | August 4th 05 05:20 PM |
NASA chokes again | Jay Honeck | Piloting | 20 | May 2nd 05 01:43 AM |
NASA Research looking for pilots with WSI in-flight weather experience | Peter R. | Piloting | 3 | October 20th 04 02:23 AM |
