Dan Horton wrote:
Dan, based on my studies, I don't think they (clutch springs) are there to drop total system resonance below idle speed......I am pretty sure that the frequency of the driveline system is already low. Good argument. Consider me corrected, with a caveat. I think you're right about driveline frequency already being low, even if there were no clutch. The caveat? The clutch springs are one of the stiffnesses in that system, and contribute to that low frequency. Take them out, frequency goes up. Design them in, frequency goes down. I wasn't disputing the effect you had described, it would be hard to disagree. My point was more along the lines of --- "are you sure that is why they are there?" Crankshaft counterweights also lower the system frequency, but thats not why they are on the crank. It is also why I am tentative in this. I don't know for a fact, so I may speculate, but will label it as speculation. I had researched it before because I had heard the story about them being detuners which I never found any support for in the literature and your numbers put to bed. The only things I have found attributed to them in engineering texts ( not websites or enthusiast pubs like Hot Rod) was shock loading and the excerpts I quoted before. Note the use of the term "damper" in the quoted text. Are you sure the text wasn't speaking of something a bit larger than our light duty clutches? Not much sign of a frictional damper in the Subaru clutch. I am pretty sure, given that the image next to the text was the classic clutch disc we are talking about. For further insight look up patent 2,674,863 It talks about the limitations of the friction mechanism in standard clutch disc dampers. I have found though that in automotive practice they seem to take a lot of liberties with the terms dampers and absorbers. Look at the term "shock absorber". And they call the detuner a balancer. I don't have a clutch disc around here at the moment to look at. I have one in a storage building across town, so may go look at it in more detail. Regarding the rubber elements someone mentioned in their driveline, "Automobile Engineers Reference" makes mention of these as well, saying that they can provide similar damping to the clutch damper Rubber elements do have a damping value, although it is very, very small. We got the actual value from Lovejoy when we were doing the modeling, but logic alone tells you it ain't much. If it had much damping value, it would melt g If you stick one in the driveline of an auto it cant help but get hit with torsional vibrations and they can be found there. We are not talking about damping at system resonance. The damping is dependent on the hysteresis of the ruber which obviously creates heat, but it is exposed to ample cooling air in a drive shaft if the amplitudes and frequencies are mild I would expect. The rubber is going to heat up if you are using them to correct for axial misalignment as well, since you will be doing the same thing to it, alternately stretching and compressing it. In any event, not my suggestion, just right out of the manual "Autombile Engineers Reference Book" by Molloy (the book does not use these terms, but the pictures make it obvious that the Layrub is a rubber in compression unit and the Rotoflex is a rubber in shear.): "A normal rear axle with a hotchkiss drive has probably adequate overall flexibility in the drive shaft aft of the gearbox, and any flexibility provided by such couplings as the Layrub and Rotoflex is probably desirable only for local effect, i.e. to reduce gearbox chatter in some cases. There does, however, in some cases seem to be a marked and very welcome quieting effect in the car from their use and this may arise from their effect in reducing the transmission of road noise. Their torsional flexibility also becomes more desireable overall where more positive and therefore more rigid drive and braking torque resisting means are provided on the axle, and even more when independent rear suspensions or a De Dion axle is used and the flexibility of the half-shafts is largely subtracted too. This aspect, torsional flexibility, can therefore be of increasing importance in the future" and "In both these cases, the axial flexibility is sufficient to make it possible to dispense witha sliding joint in the propellor shaft..." The comment about local effect is interesting and goes back to the original discussion about the springs in the clutch plate. Charles |
PSRU design advantages | ADK | Home Built | 74 | April 12th 06 09:31 PM |
light twins? | Bellsouth News Server | Home Built | 83 | August 12th 05 02:56 AM |
Aircraft engine certification FAR's | Corky Scott | Home Built | 4 | July 25th 03 06:46 PM |
