On Sun, 16 Apr 2006 19:58:19 -0500, Chris W wrote:
It seems as though those who actually read what I was really asking didn't think it was important to find or know the answer so let me get a little more specific. I am going to launch a remote control airplane that has an autopilot. The autopilot has an altitude hold function that is based on barometric pressure sensor. I will also have a GPS used for guidance. The data from that GPS will be transmitted using APRS on 144.39 mhz to any amateur station listening. Once the autopilot is turned on it will hold the pressure altitude it is at, so as it flies along it's route (maybe as many as a few hundred miles) and the barometric pressure changes the plane will climb and descend to maintain the same pressure altitude. However the only data I will be getting back is the GPS altitude. I need a way to do a reality check so if I see the plane is descending or climbing I will know it is because of changes in the barometric pressure and not the something that has gone wrong. The plan is to get the latest METAR data from the closest observation point to the current position of the plane and then do the math compared to what it was where and when it launched so I will know about what the GPS altitude should be reading as that is all I will be able to see. For those who want to know why I don't just have it transmit the pressure altitude back, I have four good reasons; cost, weight, size, complexity. My first flights will be only 20 miles or so. For safety I will be sure it steers clear of any class B, C, and D air space. I'm not sure what pressure altitude I will have it fly at .... probably somewhere between 1500' and 6000' AGL depending on the distance for it to cover. I do not believe there is any formulaic method to convert from GPS altitude to pressure altitude. GPS altitude may be more akin to true altitude, with variations based on the precise geographic location that could be placed into a table. But if altitude is varying with pressure altitude, bearing in mind that the pressure altitude sensor is also sensitive to temperature, I think you have your work cut out for yourself. Perhaps you could graph the METAR derived data and compare it with the GPS derived altitude, and if the trend (direction of change) is the same, be satisfied that the aircraft is performing as designed. If you had the lookup table to derive geographic position vs GPS altitude error; and also something like a SKEW-T plot to look at temperatures aloft; and also the METAR data, perhaps you could develop something to convert true altitude (from your corrected GPS output) to assumed pressure altitude reading on your altimeter) and draw some conclusions that way. It sounds like an interesting problem. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Pressure Altitude and Terminology | Icebound | Piloting | 0 | November 27th 04 09:14 PM |
What's minimum safe O2 level? | PaulH | Piloting | 29 | November 9th 04 07:35 PM |
GPS Altitude with WAAS | Phil Verghese | Instrument Flight Rules | 42 | October 5th 03 12:39 AM |
GPS Altitude with WAAS | Phil Verghese | Piloting | 38 | October 5th 03 12:39 AM |
