Diamond D-Jet First Flight
Old April 20th 06, 07:26 PM posted to rec.aviation.piloting
Default Diamond D-Jet First Flight
("Martin Hotze" wrote)
sorry for this ON-TOPIC *gasp* post *g*:
pulled off the Avweb newsletter:
I wonder if 25,000-ft is for quicker certification and they'll end up
applying for higher certification at a later date? Cirrus did that with
their composite airframe life numbers.
Still wondering...
I wonder how much lighter the D-Jet would be using this system?
http://www.ainonline.com/Issues/12_0...spectrum_1.htm
A MUST READ!!! :-)
"Composites are much better than aluminum, which has been used in the
aerospace industry since the 1930s," Blue asserted. He said composites are
the reason that Spectrum can develop a 10-seat twinjet with an mtow of 7,300
pounds. According to Blue, the Model 33's one-piece fuselage, complete with
integrated window and door frames, weighs a mere 309 pounds. The aircraft's
single-piece, "co-cured" wing weighs just 305 pounds."
Screw the 10 place jet - Spectrum 33 (kidding, kidding, kidding)
Screw the D-Jet/Eclipse/Mustang 4-6 seat group. (still kidding)
Give me Spectrum's construction methods (link), with a single (mini)
HondaJet engine, on a mini D-Jet single seat platform. I'm telling you
there's a market out there for this!! (Not kidding)
I'm guessing you're looking at a 300 lb plane - using the Spectrum #'s in
the link.
Single-piece wing .......40 lbs.
One-piece fuselage ... 40 lbs.
Engine ....................... 150 lbs(?) ...200 lbs(?)
[1,568-pound-thrust Williams FJ33-4A = 290 lbs]
http://world.honda.com/news/2003/c031216_1.html
[1,670-pound-thrust HF118 = 392 lbs] Super quiet! Too heavy.
What's left? ...................70 lbs. (At the very most!)
Total Empty Weight ....300 lbs. :-)))))
[450 lb. Empty Weight with an off the shelf Williams FJ33-4A engine - too
much engine? g]
Montblack
D-Jet + Cri-Cri + Star Trek 4's Transparent Aluminum + the reliability of
Honda.
Old April 20th 06, 08:14 PM posted to rec.aviation.piloting
.... and how much fuel?
Jose
The price of freedom is... well... freedom.
Old April 20th 06, 08:38 PM posted to rec.aviation.piloting
I read the lower ceiling was more an issue with RVSM. By certifying the
plane (I realize this hasn't happened yet) with a ceiling below
29,000ft RVSM equipment is not required (cost factor) and the pressure
hull doesn't need to be as stout to handle the higher cabin
differential (cost & weight factor).
Give me Spectrum's construction methods (link), with a single (mini) HondaJet engine, on a mini D-Jet single seat platform. I'm telling you there's a market out there for this!! (Not kidding)
I think an autogyro might make a better commuting vehicle. Much easier
to find a landing spot than a jet, and no type rating involved. But, a
single seat jet would be the ultimate toy for the gotta-have-it crowd.
Old April 21st 06, 05:21 AM posted to rec.aviation.piloting
("Jose" wrote)
It's basically wings, a fuel tank and a human attached to an engine.
The engine size might play a role in the final numbers. g
34 gph x 3 hrs + 1hr = 136 gallons
Full Fuel + reserve ..... .950 lbs.
Pilot and baggage .......250 lbs.
Total Useful Load ......1,200 lbs.
MontJet Empty ..............300 lbs.
MTOW ........................1,500 lbs.
440 kts
45,000 ft
1,500 (sm) range (IFR)
Montblack
Deposits are non-refundable!
Old April 21st 06, 02:59 PM posted to rec.aviation.piloting
I built a model rocket like that once. Never saw it again.
Jose
Old April 21st 06, 04:00 PM posted to rec.aviation.piloting
On Fri, 21 Apr 2006 13:59:53 GMT, Jose
I thought about doing that to my little sister, too.
Don
RAF Blind/Beam Approach Training flights Geoffrey Sinclair Military Aviation 3 September 4th 09 06:31 PM
Safety pilot - logging cross-country S Herman Instrument Flight Rules 42 December 15th 05 07:27 PM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 12th 03 11:01 PM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 09:25 AM
