I Want One - I Want One - I Want One
Old April 18th 06, 02:45 AM posted to rec.aviation.rotorcraft
Default I Want One - I Want One - I Want One
http://www.airscooter.com/pages/airscooter_main.htm
http://www.airscooter.com/pages/airs...edia_files.htm
Old April 18th 06, 10:06 AM posted to rec.aviation.rotorcraft
Me too.... right up until I read this in the FAQ:
"Question: Does the AirScooter auto-rotate?
Answer: The AirScooter is designed for the recreational sport flyer and
as such does not auto-rotate. The AirScooter is designed for
recreational flying at low altitude where even traditional helicopters
have little benefit from auto-rotation. Design efforts have been done on
a ballistic emergency chute for the AirScooter."
boB
Wing 70
U.S. Army Aviation (retired)
Central Texas - 5NM West of Gray Army Airfield (KGRK)
Old April 18th 06, 12:12 PM posted to rec.aviation.rotorcraft
Yeah me too. That engine is a new design too so who knows how reliable
it will be as used in the air scooter? No cyclic, swash plates, tail
rotor etc is all great but if the engine quits, the belt breaks or
anything else fails, you are history in this thing.
Old April 18th 06, 03:36 PM posted to rec.aviation.rotorcraft
Lawn Dart comes to mind with the designs that ignore the need for
autorotation. The claim that low altitude helicopters have little benefit
from autorotation is false. I've seen autos done from 40' agl and 40mph. I
asked Airscooter what was available to the pilot at 40 and 40 and got the
same kind of answer. If the Airscooter engine stops, the fixed pitch of the
blades will cause the rotor to slow quickly and you will be in instant ka
ka. I wouldn't think of one of these birds until I saw an engine out
demonstrated by their test pilot.
Stu Fields Baby Belle driver
www.vkss.com
"JohnO" wrote in message
Old April 18th 06, 11:47 PM posted to rec.aviation.rotorcraft
Exactly what I was thinking. :-o
Notice they try to placate the ignorant by saying that they're working on a
"ballistic emergency chute." As Stu points out, if you're low enough to not
need autorotative capabilities, you're not going to be anywhere near high
enough for a ballistic emergency chute to do you any good either.
No thanks!
Steve R.
"Stuart & Kathryn Fields" wrote in message
I
www.vkss.com
on
Old April 19th 06, 12:00 AM posted to rec.aviation.rotorcraft
So would the chute be attached above the Jesus Nut? Otherwise if the blades
are turning, where would you connect the chute?
"Steve R" wrote in message
a "ballistic emergency chute." As Stu points out, if you're low enough to
not need autorotative capabilities, you're not going to be anywhere near
high enough for a ballistic emergency chute to do you any good either.
No thanks!
Steve R.
benefit
I
www.vkss.com
and
on
*** Posted via a free Usenet account from http://www.teranews.com ***
Old April 19th 06, 12:12 AM posted to rec.aviation.rotorcraft
No thanks!
Steve R.
I
www.vkss.com
on
You know, ballistic chute and rotor craft really just don't go
together. I mean what's worse, being a lawn dart, or getting diced,
sliced and julienned? At least in the former there's only one piece
left to find and put in the casket!
Old April 19th 06, 05:06 AM posted to rec.aviation.rotorcraft
From what I remember reading in gyro circles, one group was looking at
mounting the chute on top of the rotor hub, attached via some kind of turn
buckle. "Might" be a good idea but no one was brave enough to try it out.
The only kit manufacturer that I know of that offers a ballistic chute on
their gyro is Air Command. It's been a while since I've looked at their web
site (www.aircommand.com) so I checked and a search showed that they offer a
ballistic chute option on their two place machines. The one I saw for real
was mounted below the gyro so if you ever set it off, you're going to be
coming to the ground, "inverted." :-o I'm not sure I like that idea but it
may be way better than the alternative. Again, I don't know if anyone's
tried this yet.
FWIW,
Fly Safe,
Steve R.
"Ron Snipes" wrote in message
om...
blades are turning, where would you connect the chute?
to not need autorotative capabilities, you're not going to be anywhere
near high enough for a ballistic emergency chute to do you any good
either.
No thanks!
Steve R.
benefit
40mph. I
ka
www.vkss.com
and
helicopters
on
Old April 22nd 06, 09:35 PM posted to rec.aviation.rotorcraft
Default Ballistic Chutes on rotorcraft, was I Want One - I Want One - I Want One
turn buckle. "Might" be a good idea but no one was brave enough to try
it out.
probably a bad idea on a gyro. Weight above the gimbal head plays with
flight control.
on their gyro is Air Command. It's been a while since I've looked at
their web site (www.aircommand.com) so I checked and a search showed
that they offer a ballistic chute option on their two place machines.
The one I saw for real was mounted below the gyro so if you ever set it
off, you're going to be coming to the ground, "inverted."
Larry Neal developed that, I believe, when he was working with AC (he
also centreline-thrusted their machines). Larry is now marketing his
own line of gyros, including one that's roadable as a motorcycle. He
promises a ballistic chute as a future option.
The way the Air Command chute works is in two stages, in stage one it
hangs you inverted, then when the rotation of the rotors is arrested,
you pull handle #2, releasing the low-down attach point, and you drop
around to normal orientation. No one has ever done it for real, and it
has not been tested AFAIK with models, let alone full size. In theory
it would work if everything went well and the pilot was conscious
throughout.
You'd probably want to consider a possible inverted landing at about
20-22 fps and construct an appropriate roll structure.
A Spanish company that makes copies of the BRS chutes (under the "we're
too small to be worth suing" licence apparently -- BRS are a bit
cheesed about it) has installed some on gyros. I have seen this
installation on an RAF and it is conceptually identical to Larry's Air
Command install. I have heard that the Galaxy chute company, which I
believe is Czech, has a gyro chute but haven't seen how they do it.
I doubt the total number of ballistic chutes on rotorcraft worldwide
reaches double digits. I know none has ever been deployed in angre.
There is some talk that one of Larry's current dealers will assist in
developing the chute including full size tests. A test pilot would bail
out of a ballasted & instrumented gyro at altitude and then the
ballistic would be fired by remote control. Win or lose, this would
gather useful data, and it would be safe as the pilot would be down and
away before the chute was fired. The tests will be done overseas where
regulators are more cooperative and less timid than in the USA.
:-o I'm not sure I like that idea but it may be way better than the
alternative. Again, I don't know if anyone's tried this yet.
Ballistic chutes have been saving lives for two decades on ULs, almost
as long on experimentals, for five years on certified aircraft, and
they're coming on jets.
They would be big lifesavers if they could be made to work on
gyroplanes, as the most typical gyroplane fatal is a tumble from around
pattern altitude.
They would also have potential for life savings on helicopters -- look
at the double-fatal cop crash in Michigan last week. R22 went in
vertically after apparent loss of power for reasons yet unknown.
Witnesses reported he was hovering OGE at several hundred feet of
altitiude. (Yes, he was operating in a dangerous part of the
performance envelope, but he couldn't do what he was doing -- comb
through a wooded area for a fleeing convict -- any other way, really).
Of course, a chute isn't going to be much help on a fixed-pitch
helicopter like the original subject of the thread. A gyro is always in
autorotation, a helicopter has that option in most of its performance
envelope, including the part where you always fly unless you can't
avoid it. With a fixed-pitch helicopter, you are betting your life, or
serious and painful injury, on the reliability of that motor.
cheers
-=K=-
Rule #1: Don't hit anything big.
Old April 22nd 06, 09:55 PM posted to rec.aviation.rotorcraft
Hi Kevin,
Thanks for the response. I hadn't heard bout the two stage deployment you
mention. Seems to me you've have to have plenty of altitude to have time
for everything to stabilize inverted, then deploy the second stage to right
the machine before landing. I'm not sure I'd want to go through the flip
that would occur at that point! :-o Besides, it seems to me that gyros as
a rule, don't fly high enough to take advantage of that?
Of course, all it has to do is save one life to be worth it I suppose. At
least no one's been forced to find out whether or not this will work for
real, so far! :-)
Fly Safe,
Steve R.
"Kevin O'Brien" kevin@org-header-is-my-domain-name wrote in message
news:2006042216351550073%kevin@orgheaderismydomain name...
it out.
flight control.
web site (www.aircommand.com) so I checked and a search showed that they
offer a ballistic chute option on their two place machines. The one I
saw for real was mounted below the gyro so if you ever set it off, you're
Larry Neal developed that, I believe, when he was working with AC (he also
centreline-thrusted their machines). Larry is now marketing his own line
of gyros, including one that's roadable as a motorcycle. He promises a
hangs you inverted, then when the rotation of the rotors is arrested, you
pull handle #2, releasing the low-down attach point, and you drop around
to normal orientation. No one has ever done it for real, and it has not
been tested AFAIK with models, let alone full size. In theory it would
work if everything went well and the pilot was conscious throughout.
You'd probably want to consider a possible inverted landing at about 20-22
too small to be worth suing" licence apparently -- BRS are a bit cheesed
about it) has installed some on gyros. I have seen this installation on an
RAF and it is conceptually identical to Larry's Air Command install. I
have heard that the Galaxy chute company, which I believe is Czech, has a
out of a ballasted & instrumented gyro at altitude and then the ballistic
would be fired by remote control. Win or lose, this would gather useful
data, and it would be safe as the pilot would be down and away before the
chute was fired. The tests will be done overseas where regulators are more
Ballistic chutes have been saving lives for two decades on ULs, almost as
long on experimentals, for five years on certified aircraft, and they're
coming on jets.
They would be big lifesavers if they could be made to work on gyroplanes,
as the most typical gyroplane fatal is a tumble from around pattern
altitude.
They would also have potential for life savings on helicopters -- look at
the double-fatal cop crash in Michigan last week. R22 went in vertically
after apparent loss of power for reasons yet unknown. Witnesses reported
he was hovering OGE at several hundred feet of altitiude. (Yes, he was
operating in a dangerous part of the performance envelope, but he couldn't
do what he was doing -- comb through a wooded area for a fleeing
Of course, a chute isn't going to be much help on a fixed-pitch helicopter
like the original subject of the thread. A gyro is always in autorotation,
a helicopter has that option in most of its performance envelope,
including the part where you always fly unless you can't avoid it. With a
fixed-pitch helicopter, you are betting your life, or serious and painful
cheers
-=K=-
