Prop Blade Wiggles on C182
Old April 22nd 06, 07:08 AM posted to rec.aviation.owning
Default Prop Blade Wiggles on C182
A local pilot called me with a preflight issue of a propeller blade on
C182 being a bit loose in its socket. Holding the blade tip, he could
wiggle it front to back and twist it slightly, changing its pitch.
Some mechanics told him it was safe to fly home.
Anyone disagree?
Old April 22nd 06, 07:25 AM posted to rec.aviation.owning
Anyone disagree?
This is normal (to a degree). McCauley calls it "Blade Shake", and is a
result of the fit of the blade root in to the hub bearing. Statically,
there will be some "slop" (up to 1/8" at the tip is acceptable), but
under rotational loads, this "slop" will disappear.
Happy Flying!
Scott Skylane
N92054
Old April 22nd 06, 01:50 PM posted to rec.aviation.owning
This is ONLY normal for variable pitch propellers.
And even then, we are talking measurements that are barely perceptible to
the human eye. I personally would not have flown that plane without it
being further checked into.
Having been through replacing the front bulkhead (cracked due to unbalanced
prop) and overhauling the spinner due to an unbalance prop, I learned that
balancing is down to a .10 of a gram so there is some serious precision in
the art of the propeller. Prop only has 2400 hours on it (total airframe
time is the same).
Having seen what it took to get my bird back into specs, blade shake would
make me question whether there was a problem more then just the propeller
since we are only talking .125 of an inch.
See http://www.mccauley.textron.com/svcl.../sl1989-2C.pdf for
specific details regarding blade shake.
Allen
Old April 22nd 06, 03:29 PM posted to rec.aviation.owning
The original poster didn't quantify the movements of the propeller, but
based on the document quoted, I don't see any cause for concern unless
the propeller movements were far in excess of the recommendation. The
bottom line is that some shake and twist are normal, but a propeller
blade that is excessively "loose" in the hub is not normal.
Balance is an entirely different issue.
JKG
Old April 22nd 06, 05:45 PM posted to rec.aviation.owning
My Aviat Husky' Lycoming 0-360 with a Hartzell constant speed prop
always has 1/8"-1/4" play front to back coming from the crankshaft I
think. It always seem a little excessive, compared to others, but never
was a problem. Engine and prop is beyond TBO and still going strong....
Old April 22nd 06, 07:33 PM posted to rec.aviation.owning
About an 1/8" fore and aft, and a degree or two of twist is what my has
had for
about 20 years. Due to centrifical force, the blade seats against its
retention collar when
it is spinning...
Old April 23rd 06, 03:30 AM posted to rec.aviation.owning
Fore and aft crankshaft play is the engine's thrust bearing clearance and
play is normal. It may seem like 1/4 inch but actually is less.
Kent Felkins
Tulsa
"Doug" wrote in message
*** Posted via a free Usenet account from http://www.teranews.com ***
Old April 23rd 06, 05:32 AM posted to rec.aviation.owning
Thanks for the info. The pilot in question was always in the habit of
tugging on the prop during his preflight, so this wiggle was new. I
don't know how much movement it displayed.
Old April 23rd 06, 05:33 AM posted to rec.aviation.owning
retention collar when it is spinning...
Thanks; I'll feed this to the pilot for what normal is.
Old April 24th 06, 12:57 AM posted to rec.aviation.owning
Uhh, yeah...I'd think so. **Fixed-pitch** props are solid pieces of
aluminum, tip to tip. NOT GOOD if one of those shows some "play".
Advancement of prop blade in flight, new information Corky Scott Piloting 35 August 28th 04 02:00 PM
Survey - 3 blade prop conversion- Cockpit vibration, happy or not Fly Owning 20 June 30th 04 05:32 PM
Hartzelll 3 blade prop Matt Whiting Owning 6 June 15th 04 01:29 AM
Pitch and Diameter of 3 blade prop for IO-360 200HP Bart D. Hull Home Built 1 December 11th 03 11:42 PM
IVO props... comments.. Dave S Home Built 16 December 6th 03 11:43 PM
