IAP without inbound course?
Old April 23rd 06, 02:37 AM posted to rec.aviation.ifr
Default IAP without inbound course?
Roy Smith wrote:
Sam Spade wrote:
There is only one of those beasts in existence. If that what the "drill
instructor" was looking for, then it was an exercise in silliness.
And that makes in inappropriate for this newsgroup how?
Beats me. I did not suggest that. I suggested the "drill instructor"
was being silly if he was looking for the answer to be "that one DME ARC
IAP."
Old April 23rd 06, 03:44 AM posted to rec.aviation.ifr
I suggested the "drill instructor" was being silly if he was looking for the answer to be "that one DME ARC IAP."
I disagree.
To bust somebody on a question like that would have been more than
silly. However, =asking= the question, as a "bonus question", is a way
of examining people's unstated assumptions about flight and the
environment in which we aviate. This is always a good thing.
Jose
The price of freedom is... well... freedom.
Old April 23rd 06, 10:53 AM posted to rec.aviation.ifr
I disagree.
Jose
I agree, asking the question is appropriate and thought-provoking. But,
if the "drill instructor" was thinking in terms of DME ARC IAPs, then
that was silly. But, as I said at the beginning, he may have been
thinking of ASR and PAR.
In any case, based on the information available, there is a tad of
speculation going on here.
Old April 23rd 06, 03:23 PM posted to rec.aviation.ifr
But, if the "drill instructor" was thinking in terms of DME ARC IAPs, then that was silly.
Not at all. I bet most people don't know the parameters of a DME arc,
and most have never flown them, even in practice.
"They're not all like that" is a very important thing to learn, and
examples pop up in the oddest places. My wish is that they never pop up
at inopportune times.
Jose
Old April 23rd 06, 04:08 PM posted to rec.aviation.ifr
Jose
How? There is only one such IAP in the country (probably the world).
If, however, you mean most pilots don't know how to fly DME ARC initial
approach segments, then their training is seriously lacking.
Old April 24th 06, 12:01 AM posted to rec.aviation.ifr
There is only one such IAP in the country (probably the world). If, however, you mean most pilots don't know how to fly DME ARC initial approach segments, then their training is seriously lacking.
Then count me in. I was never taught the procedure; I asked here some
time ago and practiced it on my own. However, my training is not
"seriously lacking". The DME arcs were not around much (DME was not in
the aircraft either) when I took my training. I've kept up, but one
cannot keep up with what one does not know to keep up with, and some of
those things are obscure "gotchas".
Jose
Old April 24th 06, 12:15 AM posted to rec.aviation.ifr
The secret of flying a DME arc is the initial heading you
turn to when at the first fix and then turning to a heading
every 10 degrees of radial change, probably a 20 degree turn
each ten degrees on the arc. You can even stay pretty close
without a DME or GPS by guessing at a wind correction angle.
You can try using VOR cross bearings to set the first turn
fix and then try the first turn 90 degrees from the radial,
with about 5 degrees inside the turn. Then adjust the
heading as you cross each 10 degree radial. When you get to
the inbound course, less 10 degrees, turn to intercept.
Have somebody use a handheld GPS to monitor your distance,
but don't "fly" the GPS, this is a VFR dead reckoning
experiment.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Jose" wrote in message
news | There is only one such IAP in the country (probably the
asked here some
is not
(DME was not in
up, but one
with, and some of
| Jose
Old April 24th 06, 01:02 AM posted to rec.aviation.ifr
news
DME arcs were much more common years ago than they are today.
Old April 24th 06, 02:25 AM posted to rec.aviation.ifr
Jose
The procedure for flying DME ARCs was in the old instrument flying
handbook, both with and without an RMI.
I was never taught the procedure, either, when I obtained my instrument
rating. But, as a professional CFI-I, I became proficient in their use
and how to teach them as soon as it became apparent (circa late 1960s)
that they better be part of the proficient instrument pilot's toolkit.
Old May 9th 06, 04:25 AM posted to rec.aviation.ifr
They used to have several DME ARC final approaches in Germany. The
military especially used them as backup procedures to get to the airport
if the base facilities were off the air, and sometimes as primary
procedures if there weren't any on-field facilities. Most of the time
the arc didn't line you up with the runway centerline unless the
facility just happened to be perfectly abeam the airport.
John
more bitching about the IFR written - CDI left/right versus north/south/etc G. Sylvester Instrument Flight Rules 58 January 12th 05 02:32 AM
GPS 430 or 480? Hankal Instrument Flight Rules 35 November 3rd 04 10:23 PM
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Busy day for MilComms Monitoring - Wed, 7 Apr 2004 AllanStern Military Aviation 7 May 11th 04 07:29 AM
Lost comms after radar vector Mike Ciholas Instrument Flight Rules 119 January 31st 04 11:39 PM
