ILS question
Old June 17th 04, 02:30 PM
Steven P. McNicoll
wrote in message ...
That's what they're supposed to do.
What do you base that on?
Old June 17th 04, 02:51 PM
5-9-1 requirement to issue an altitude compatible with an NPA or an altitude
below the G/S for a PA.
"b. For a precision approach, at an altitude not above the
glideslope/glidepath or below the minimum glideslope intercept altitude
specified on the approach procedure chart.
c. For a nonprecision approach, at an altitude which will allow descent in
accordance with the published procedure."
Even if he was vectored onto "final" 50 miles out, 5-9-4 leads to 5-9-1.
This stuff is written to make the IAP flyable, not to provide loopholes for
controllers. ;-)
Old June 17th 04, 03:38 PM
Steven P. McNicoll
altitude below the G/S for a PA.
in accordance with the published procedure."
That's swell, but you said controllers were supposed to step down to the
altitude shown on the chart. Where is that requirement?
for controllers. ;-)
I think you'll find that 5-9-4 follows 5-9-1.
Old June 17th 04, 07:43 PM
I guess it depends on the definition of "is."~
Great observation! Also, there is the issue of context:
5-9-4 Arrival Instructions
Issue all of the following to an aircraft before it reaches the approach gate:
"Approach gate" sorta ties 5-9-4 to 5-9-1.
Question: DP altitude vs MCA/MEA Doug Easton Instrument Flight Rules 7 April 7th 04 03:29 AM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 01:51 AM
