#11
![]() "Jim Macklin" wrote in message news:nqW2g.7077$ZW3.4090@dukeread04... That's is true, but except for the Beech 18, are there any HS props on an airplane under 12,500 pounds? The feathering on the HS is a electrical relay that turns on a high pressure pump that operates at a pressure above governor pressure. The Prop is feathered and the pump shuts off. To unfeather the button is held in so the pump continues to run and that causes the internal valve to move, re-routing the oil so it unfeathers. I wonder many pilots will take this to heart and open their POH to the systems section? -- James H. Macklin ATP,CFI,A&P Oh for the simple life of fighters!! :-) I used Hamilton Standard props quite a lot, but few of them feathered. The 24D50 on my Mustang didn't feather of course :-) If I remember right, the pitch range on my prop was something like 42 degrees. Dudley |
![]() "Jim Macklin" wrote in message news:lqW2g.7075$ZW3.2577@dukeread04... I look forward to winning the lottery and buying you a drink. Jim Hell, unless one of us has to put gas in our cars, we should be able to afford a bottle of Jack Daniels between us :-))) Dudley "Dudley Henriques" wrote in message link.net... | I've done this a few times myself. :-) | On Usenet, if you underpost someone already in the thread but NOT the | original poster, what you post is considered addressed to the person you | underposted rather than simply an addition to the general thread. | Any general comment should be picked up as a post to the original poster by | clicking his/her post for reply. Then the comment appears referenced to the | initial question and not the sub poster. | I did the same thing once and gave a hundred word "lecture" on how to do a | slow roll to one of the world's best acro pilots by accidentally picking him | up to underpost instead of the initial poster who had asked about rolls. :-) | The pilot I gave the lecture to simply gave me a one word reply "Thanks" | with a smilie attached :-) | That get together sounds like fun. I'll bring the bottle! | Dudley | | | | "Jim Macklin" wrote in message | news:nZT2g.6827$ZW3.3603@dukeread04... | No, I know that, I just tacked it on the thread for the | benefit of the others. I think most pilots and many | mechanics don't really understand these things, judging by | the number of twins that feather before the prop lever gets | to the gate. | | If I win the lottery, odds 146 million to one, we can have | that CFI round table and sell tickets to anyone without a | CFI. CFIs can come for free. I'll pay for you and me. If I | don't win the lottery, it will have to be in Wichita, can't | afford to go elsewhere without the lottery. ;-)' | | -- | James H. Macklin | ATP,CFI,A&P | | -- | The people think the Constitution protects their rights; | But government sees it as an obstacle to be overcome. | some support | http://www.usdoj.gov/olc/secondamendment2.htm | See http://www.fija.org/ more about your rights and duties. | | | "Dudley Henriques" wrote in | message | nk.net... | | If all this was meant for me, I'm pretty sure I just | might already know | | these things | | :-) | | Dudley Henriques | | | | "Jim Macklin" wrote | in message | | news:yZS2g.6789$ZW3.6526@dukeread04... | | The prop governor controls within a range and should | hold a | | steady rpm within that range. When the run-up is done | at | | say, 2400 rpm the prop should be cycled to the minimum | rpm | | and allowed to stabilize for a few seconds to check that | the | | governor is working properly. On a multiengine airplane | the | | prop should be reduced to just outside the feather | detent | | and allowed to run for several seconds to be sure that | the | | prop isn't feathering at the minimum governed speed | [usually | | 2000 rpm on most piston engines]. If the prop control | is | | not rigged properly the prop will feather too soon. | Then | | the prop feather check should be done. | | | | Most props have a certain amount of internal leakage to | keep | | warm oil circulating in the prop hub, but several cycles | on | | a cold engine/prop will assure that the prop does reach | | proper operating temperatures. | | | | In very cold temperatures, I like to vary the rpm every | some | | often to be sure the prop is functioning, but normal | | internal flow should make this mostly an unneeded habit. | | | | Remember, on a single-engine reducing rpm send oil to | the | | prop and on a multi, reducing rpm/feathering drain oil | from | | the prop. | | | | | | -- | | James H. Macklin | | ATP,CFI,A&P | | | | -- | | The people think the Constitution protects their rights; | | But government sees it as an obstacle to be overcome. | | some support | | http://www.usdoj.gov/olc/secondamendment2.htm | | See http://www.fija.org/ more about your rights and | duties. | | | | | | "Dudley Henriques" wrote in | | message | | | ink.net... | | | | | | "Frode Berg" wrote in message | | | ... | | | Hi! | | | | | | I was told by my mechanic to only pull the prop | handle | | until I could | | | audibly | | | hear a slight pitch change to establish that it was | | working. | | | | | | However, the aircraft manual says it should be | cycled | | completely, and on a | | | cold engine three times to make sure oil is applied | to | | the governor, or | | | the | | | pitch mechanism. | | | | | | Can someone elaborate on this? | | | | | | What is recommended? | | | | | | Thanks, | | | | | | Frode | | | | | | POH rules of course, but aside from that, I always | liked | | to exercise a prop | | | through several cycles, especially when cold, just to | get | | everything nice | | | and warm and fluid up there. | | | Dudley Henriques | | | | | | | | | | | | | | | | | | |
On Sun, 23 Apr 2006 21:06:12 -0500, "Jim Macklin"
wrote: That's is true, but except for the Beech 18, are there any HS props on an airplane under 12,500 pounds? The feathering on the HS is a electrical relay that turns on a high pressure pump that operates at a pressure above governor pressure. The Prop is feathered and the pump shuts off. To unfeather the button is held in so the pump continues to run and that causes the internal valve to move, re-routing the oil so it unfeathers. Heh. I typically "cycled" a freshly o-hauled HS to feather and back static, then started the engine and function-checked it after installation. Got really busy one afternoon/evening, cycled the prop, but didn't get the test run in. Aircraft in question got dispatched on a last minute run-and I got a phone call @ 3:00 am. Line guy hopped up on the wing and topped off the oil tank (to replace what I had pumped into the engine). When the plane arrived at its destination, the pilot attempted to check the oil-took the cap off, oil started running out, cap back on, called home and asked for help. Was also a really pretty fan-shaped spray pattern of oil on the ramp where the run-up was done prior to the first departure. I wonder many pilots will take this to heart and open their POH to the systems section? In this forum, probably quite a few. TC |
Sounds good. Right now I'm trying some cheap brandy, but
Jack is awfully good. I don't drink much, maybe one once a week now. But I'm going to have one tonight, a toast to all the WWII pilots, to Scott Crossfield, to Dale Earnhardt and to Tiger Woods dad. And all the troops in harm's way. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Dudley Henriques" wrote in message nk.net... | | "Jim Macklin" wrote in message | news:lqW2g.7075$ZW3.2577@dukeread04... | I look forward to winning the lottery and buying you a | drink. | | Jim | | Hell, unless one of us has to put gas in our cars, we should be able to | afford a bottle of Jack Daniels between us :-))) | Dudley | | | | "Dudley Henriques" wrote in | message | link.net... | | I've done this a few times myself. :-) | | On Usenet, if you underpost someone already in the thread | but NOT the | | original poster, what you post is considered addressed to | the person you | | underposted rather than simply an addition to the general | thread. | | Any general comment should be picked up as a post to the | original poster by | | clicking his/her post for reply. Then the comment appears | referenced to the | | initial question and not the sub poster. | | I did the same thing once and gave a hundred word | "lecture" on how to do a | | slow roll to one of the world's best acro pilots by | accidentally picking him | | up to underpost instead of the initial poster who had | asked about rolls. :-) | | The pilot I gave the lecture to simply gave me a one word | reply "Thanks" | | with a smilie attached :-) | | That get together sounds like fun. I'll bring the bottle! | | Dudley | | | | | | | | "Jim Macklin" wrote | in message | | news:nZT2g.6827$ZW3.3603@dukeread04... | | No, I know that, I just tacked it on the thread for the | | benefit of the others. I think most pilots and many | | mechanics don't really understand these things, judging | by | | the number of twins that feather before the prop lever | gets | | to the gate. | | | | If I win the lottery, odds 146 million to one, we can | have | | that CFI round table and sell tickets to anyone without | a | | CFI. CFIs can come for free. I'll pay for you and me. | If I | | don't win the lottery, it will have to be in Wichita, | can't | | afford to go elsewhere without the lottery. ;-)' | | | | -- | | James H. Macklin | | ATP,CFI,A&P | | | | -- | | The people think the Constitution protects their rights; | | But government sees it as an obstacle to be overcome. | | some support | | http://www.usdoj.gov/olc/secondamendment2.htm | | See http://www.fija.org/ more about your rights and | duties. | | | | | | "Dudley Henriques" wrote in | | message | | | nk.net... | | | If all this was meant for me, I'm pretty sure I just | | might already know | | | these things | | | :-) | | | Dudley Henriques | | | | | | "Jim Macklin" | wrote | | in message | | | news:yZS2g.6789$ZW3.6526@dukeread04... | | | The prop governor controls within a range and should | | hold a | | | steady rpm within that range. When the run-up is | done | | at | | | say, 2400 rpm the prop should be cycled to the | minimum | | rpm | | | and allowed to stabilize for a few seconds to check | that | | the | | | governor is working properly. On a multiengine | airplane | | the | | | prop should be reduced to just outside the feather | | detent | | | and allowed to run for several seconds to be sure | that | | the | | | prop isn't feathering at the minimum governed speed | | [usually | | | 2000 rpm on most piston engines]. If the prop | control | | is | | | not rigged properly the prop will feather too soon. | | Then | | | the prop feather check should be done. | | | | | | Most props have a certain amount of internal leakage | to | | keep | | | warm oil circulating in the prop hub, but several | cycles | | on | | | a cold engine/prop will assure that the prop does | reach | | | proper operating temperatures. | | | | | | In very cold temperatures, I like to vary the rpm | every | | some | | | often to be sure the prop is functioning, but normal | | | internal flow should make this mostly an unneeded | habit. | | | | | | Remember, on a single-engine reducing rpm send oil | to | | the | | | prop and on a multi, reducing rpm/feathering drain | oil | | from | | | the prop. | | | | | | | | | -- | | | James H. Macklin | | | ATP,CFI,A&P | | | | | | -- | | | The people think the Constitution protects their | rights; | | | But government sees it as an obstacle to be | overcome. | | | some support | | | http://www.usdoj.gov/olc/secondamendment2.htm | | | See http://www.fija.org/ more about your rights and | | duties. | | | | | | | | | "Dudley Henriques" wrote | in | | | message | | | | | | ink.net... | | | | | | | | "Frode Berg" wrote in | message | | | | ... | | | | Hi! | | | | | | | | I was told by my mechanic to only pull the prop | | handle | | | until I could | | | | audibly | | | | hear a slight pitch change to establish that it | was | | | working. | | | | | | | | However, the aircraft manual says it should be | | cycled | | | completely, and on a | | | | cold engine three times to make sure oil is | applied | | to | | | the governor, or | | | | the | | | | pitch mechanism. | | | | | | | | Can someone elaborate on this? | | | | | | | | What is recommended? | | | | | | | | Thanks, | | | | | | | | Frode | | | | | | | | POH rules of course, but aside from that, I always | | liked | | | to exercise a prop | | | | through several cycles, especially when cold, just | to | | get | | | everything nice | | | | and warm and fluid up there. | | | | Dudley Henriques | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | |
Jim Macklin wrote
But if you are flying a multiengine aircraft in cold weather and shut an engine down in training including feathering, the oil may congeal to the point the prop won't unfeather. So ME CFI be careful what and where you practice. That is true of course unless you happen to be flying a big turboprop that uses something similiar to hydraulic oil for its prop control mechanism. We routinely shutdown (feathered) numbers 1 and 4 for endurance purposes. Bob Moore Allison T-56 operator |
Skydrol and similar are great. Turbine oil is also mostly
synthetic and doesn't congeal. But most people don't fly C 130s and hang out here, in rec.piloting. Most ME training is done in a piston powered light twin with petroleum based engine oil shared by the prop. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Bob Moore" wrote in message . 121... | Jim Macklin wrote | | But if you are | flying a multiengine aircraft in cold weather and shut an | engine down in training including feathering, the oil may | congeal to the point the prop won't unfeather. So ME CFI be | careful what and where you practice. | | That is true of course unless you happen to be flying a big | turboprop that uses something similiar to hydraulic oil for | its prop control mechanism. We routinely shutdown (feathered) | numbers 1 and 4 for endurance purposes. | | Bob Moore Allison T-56 operator |
Jim & Dudley, I've a question I've been meaning to ask.
"Jim Macklin" wrote in message news:yZS2g.6789$ZW3.6526@dukeread04... The prop governor controls within a range and should hold a steady rpm within that range. When the run-up is done at say, 2400 rpm the prop should be cycled to the minimum rpm and allowed to stabilize for a few seconds to check that the governor is working properly. On a multiengine airplane the prop should be reduced to just outside the feather detent and allowed to run for several seconds to be sure that the prop isn't feathering at the minimum governed speed [usually 2000 rpm on most piston engines]. What is the minimum governed speed on a constant speed prop? It has been my experience that below 1200-1400 rpm someplace, a C/s prop will no longer cycle. In a glide, the RPM is generally below that. In another thread, some time ago, you(Jim) mentioned that to get the best glide out of a single engine(without the engine), one should pull the prop control out fully. I have tried this in a Mooney 201, and could not make the RPM change a bit, (Power off, best glide). Have any of you ever been able in influence a glide with the prop control? Al |
On the C-182 I have always been told to cycle 3 time just enough for a 200 rpm
drop. This verifies it is working and the oil is flowing. Ron Frode Berg wrote: Hi! I was told by my mechanic to only pull the prop handle until I could audibly hear a slight pitch change to establish that it was working. However, the aircraft manual says it should be cycled completely, and on a cold engine three times to make sure oil is applied to the governor, or the pitch mechanism. Can someone elaborate on this? What is recommended? Thanks, Frode |
But did you notice a change in rate of descent when you
repositioned the prop? The rpm may not change but it should change the blade angle and thus the drag. -- James H. Macklin ATP,CFI,A&P "Al" wrote in message ... | Jim & Dudley, I've a question I've been meaning to ask. | | | "Jim Macklin" wrote in message | news:yZS2g.6789$ZW3.6526@dukeread04... | The prop governor controls within a range and should hold a | steady rpm within that range. When the run-up is done at | say, 2400 rpm the prop should be cycled to the minimum rpm | and allowed to stabilize for a few seconds to check that the | governor is working properly. On a multiengine airplane the | prop should be reduced to just outside the feather detent | and allowed to run for several seconds to be sure that the | prop isn't feathering at the minimum governed speed [usually | 2000 rpm on most piston engines]. | | What is the minimum governed speed on a constant speed prop? | | It has been my experience that below 1200-1400 rpm someplace, a C/s prop | will no longer cycle. In a glide, the RPM is generally below that. In | another thread, some time ago, you(Jim) mentioned that to get the best glide | out of a single engine(without the engine), one should pull the prop control | out fully. I have tried this in a Mooney 201, and could not make the RPM | change a bit, (Power off, best glide). | | Have any of you ever been able in influence a glide with the prop | control? | | Al | | | | | |
Hi Al;
May I refer you to an article written by John Deakin. John has written an excellent explanation for exactly what you are asking about here. http://www.avweb.com/news/columns/182082-1.html All the best, Dudley "Al" wrote in message ... Jim & Dudley, I've a question I've been meaning to ask. "Jim Macklin" wrote in message news:yZS2g.6789$ZW3.6526@dukeread04... The prop governor controls within a range and should hold a steady rpm within that range. When the run-up is done at say, 2400 rpm the prop should be cycled to the minimum rpm and allowed to stabilize for a few seconds to check that the governor is working properly. On a multiengine airplane the prop should be reduced to just outside the feather detent and allowed to run for several seconds to be sure that the prop isn't feathering at the minimum governed speed [usually 2000 rpm on most piston engines]. What is the minimum governed speed on a constant speed prop? It has been my experience that below 1200-1400 rpm someplace, a C/s prop will no longer cycle. In a glide, the RPM is generally below that. In another thread, some time ago, you(Jim) mentioned that to get the best glide out of a single engine(without the engine), one should pull the prop control out fully. I have tried this in a Mooney 201, and could not make the RPM change a bit, (Power off, best glide). Have any of you ever been able in influence a glide with the prop control? Al |
PA28: Difference in constant speed prop vs fixed pitch | Nathan Young | Owning | 25 | October 10th 04 04:41 AM |
Prop Pitch Question | Eugene Wendland | Home Built | 2 | April 25th 04 03:22 AM |
Pitch and Diameter of 3 blade prop for IO-360 200HP | Bart D. Hull | Home Built | 1 | December 11th 03 11:42 PM |
IVO props... comments.. | Dave S | Home Built | 16 | December 6th 03 11:43 PM |
ALTRAK pitch system flight report | optics student | Home Built | 2 | September 21st 03 11:49 PM |
