An amphibian that sank?
Old April 24th 06, 12:29 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Default An amphibian that sank?
The only unsinkable boat I know about is the Boston Whaler
www.whaler.com which is made of two fiberglass shells bonded
together with the inside filled 100% with foamed in-place
resin that makes it one solid boat. They even can be cut
into sections and the still get you to shore with dry feet.
But aluminum floats don't work well with foam inside because
of corrosion between the foam and metal. A better solution
is to fill the compartments with ping-pong balls. They
displace water, don't weigh too much and can be removed for
inspection and corrosion control.
James H. Macklin
ATP,CFI,A&P
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"Morgans" wrote in message
| "Flyingmonk" wrote in message
| http://www.divingservices.net/aircraft.jpg
| http://www.divingservices.net/9bcess2.jpg
| Anyone have the story behind this? Strange that a plane
designed to
| float, sank!
| You might be surprised how many recreational boats sink.
There are dozens
| of thing that can happen. Most common are drain plug left
out/loose, seals
| or hoses leaking and slowly filling the boat.
| Jim in NC
Old April 24th 06, 12:39 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
"Morgans" wrote:
"Roy Smith" wrote
One of the fundamental truths of boat design is that the center of gravity
has to be lower than the center of bouyancy. If it's not, then eventually
the boat (helicopter, whatever) will figure out how to turn itself over so
that it is.
Not completely true, but right to a degree.
In the case of a heli or plane on floats, the center
of gravity is way higher than the center of buoyancy,
and everything continues to work out OK.
In that case the center of gravity is between the
outer points of buoyancy. Like this:
GGG
BB BB
Then if it gets a little sideways, and the gravity
is on the outside of buoyancy, things will re-adjust.
GGG BB
BB
Ker-splash! Soon it is stable again, but
in a bad (g) way:
BB BB
GGG
Exactly. The heli has indeed figured out how to turn itself over and put
its CG below its CB.
Old April 24th 06, 01:19 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
James H. Macklin
ATP,CFI,A&P
Some of the small sail boats also have foam filled compartments with the
same effect. The name MacGreggor comes to mind from years ago, and there
are probably others by now.
Peter
Old April 24th 06, 01:50 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
that it is.
Absolutly wrong. The center of bouyancy of most large boats and ships
is well below the center of gravity.
John (I Took Naval Science) Kimmel
GET YER STINKING PAWS OFF ME YOU DAMN DIRTY APE!
Old April 24th 06, 02:00 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Barf. Never use "MacGregor" and "sailboat" in the same sentence. They are
the most butt-ugly things in the universe.
Old April 24th 06, 02:18 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
that it is.
I saw a head-on picture of a carrier and boy did it look top heavy...
The Monk
GET YER STINKING PAWS OFF ME YOU DAMN DIRTY HUMAN! ~ Panet of the Apes
II
Old April 24th 06, 02:19 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
"Grumman-581" wrote in message
"Roy Smith" wrote in message
23.751 Main float buoyancy.
(a) Each main float must have
I don't see anything in there that would require the supposedly watertight
compartments to still provide floatation in the event of them no longer
being watertight...
There's not.
However, I have heard of seaplane owners who have done things like fill
their wings (or other easily accessed compartments) with ping-pong balls,
for this purpose.
Generally speaking though, seaplanes don't have any filler material, such as
styrofoam or what have you the way boats do. I think it's likely that this
is because, as light as styrofoam is, when you fill every empty space of an
airplane with it, that's still useful load you lose.
Of course, there are also the certification and maintenance issues as well.
The bottom line is, I believe, that it's much simpler to put a bunch of
lightweight filler material in a boat than in an airplane.
Pete
Old April 24th 06, 02:36 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
there
are
They actually did have a replica of a 19th century pilot boat that I thought
was sort of neat, if less than practical, and commercially it was a dismal
failure. But I really don't like most of their competitors boats very much
either.
Peter
Old April 24th 06, 04:18 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
that it is.
GGG
BB BB
GGG BB
BB
in a bad (g) way:
BB BB
GGG
Jim in NC
Uh, Houston, we are in Stable -two.
Old April 24th 06, 04:21 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
there
are
either.
Peter
That must have been the 23 foot. Cute little ship.
Right down to the bow sprit.
I've been looking at a Catalina Capri 18.
Can't decide if it's too big, or too small, or just right...
Richard
Amphibian VTOL? Flyingmonk Piloting 6 January 6th 06 12:18 AM
Amphibian Aviat Husky Doug Aviation Marketplace 0 November 22nd 04 06:03 AM
Adventure Air Amphibian accident Ed Baker Home Built 3 November 12th 04 01:46 PM
New amphibian aircraft Sten-Anders Fellman Products 0 August 28th 04 11:47 PM
Amphibian down on Mt Kearsarge [email protected] Piloting 2 July 7th 04 11:32 AM
