Would you fly this one?
Old April 24th 06, 04:28 AM posted to rec.aviation.rotorcraft,rec.aviation.piloting
Default Would you fly this one?
Hey Jim? What's your latest wood working project? I'm looking for a
cheap table for my router, any ideas?
The Monk
Old April 24th 06, 04:54 AM posted to rec.aviation.rotorcraft,rec.aviation.piloting
Default OT woodworking - was:Would you fly this one?
"Flyingmonk" wrote in message
Go to the library, and look through Fine Woodworking magazine, and a couple
of others, and find a home brewed router table you like the looks of. The
home built ones are usually superior to any reasonably priced store bought
ones - too flimsy.
There are a couple brands of router mountings that make a more precise,
easier adjusting, and easier access setup for changing bits, that are made
for home brew tables. they are not a requirement for most setups, but they
are nice for changes and precision.
I have never made one, since I have a big ole hunk of cast iron shaper at my
fingertips. (and yes, I still have all of them- knock on wood) I have
considered it at times, since they will do some jobs better than a shaper.
Key things to look for is ease of changing setups, and ease of repeatability
for precision. The fence should be micro adjustable, with some type of
threaded rod or bolt controlling the changes. The infeed and outfeed of the
fence should be adjustable independently, if at all possible. One good
thing about that kind of setup is that you can use it as a jointer, then.
Secondary, is ease of bit changes, and third, a good sawdust collection
system. It should also have grooves for guiding miter jigs or custom made
sliding beds.
Shoot, you probably can find that kind of stuff online, now.
Jump over to the woodworking groups. Some of them are pretty active, but
believe it or not, you will find some people over there to be more
opinionated and abusive, than here! Hard to believe, huh?
My latest project is coming to a close. (I hope) I gutted my kitchen, and
built all new cabinets, tiled the counter tops and floors, and also built
raised panel doors for all of them. It has been a monster, and I will be
glad to get it done. Sanding and finishing is next. Yuck!
Jim in NC
Old April 24th 06, 04:58 AM posted to rec.aviation.rotorcraft,rec.aviation.piloting
"Flyingmonk" wrote
What's the deal w/ the counter weight? Why not have two blades and use
that dead weight to generate lift?
Believe it or not, every additional blade means a loss of efficiency. One
blade should hover and fly on less HP than two blade. That says nothing for
smoothness, and I would think that setup would be totally unacceptable, for
that one.
Jim in NC
Old April 24th 06, 05:18 AM posted to rec.aviation.rotorcraft,rec.aviation.piloting
One small step for a man...
One giant leap for humanburger.
My apologies to Neil Armstrong.
Flyingmonk wrote:
http://1000aircraftphotos.com/Helicopters/999.htm
The Monk
Old April 24th 06, 06:48 AM posted to rec.aviation.rotorcraft,rec.aviation.piloting
for smoothness, and I would think that setup would be totally
unacceptable, for that one.
I have seen propellers for a model airplane that had only one blade, with
a counter weight... has it ever been made for a full scale aircraft?
--Sylvain
Old April 24th 06, 01:39 PM posted to rec.aviation.rotorcraft,rec.aviation.piloting
In article .com,
says...
The picture about four slides later is not bad either!
http://1000aircraftphotos.com/Helicopters/1046.htm
Buzzsaw in the breadbasket - front and rear!
How much efficiency would be sacrificed by putting a wireframe guard
around these things? I don't mean a tight mesh that you couldn't still
get a finger into - but at least something rigid enough to keep you
from slipping in up to your waist! Damn.
GF
Old April 24th 06, 01:51 PM posted to rec.aviation.rotorcraft,rec.aviation.piloting
Holy Crap!
Is the pilot really as close to the blades as it appears?
Old April 24th 06, 08:40 PM posted to rec.aviation.rotorcraft,rec.aviation.piloting
("Greg Farris" wrote)
"Please DO NOT remove Shopping Carts from the parking lot."
Montblack
Old April 25th 06, 11:36 AM posted to rec.aviation.rotorcraft,rec.aviation.piloting
Damn, is the least you can say? Double damn!
Ever seen a prop spin off of a model airplane engine? I have.
I was testing the needle setting by holding it pointed straight up, wide
open throttle. If it sags, going lean pointed up like that, then it needs
more adjustment.
For what ever reason, (either it got loosened, or I forgot to tighten it) it
suddenly departed the engine. I was surprised (understatement of the year)
to see it continuing to spin, in the same rotational plane. With no weight
holding it down, the thrust lifted the prop straight up into the air about 5
feet rather quickly; then it arced back over my head. (and two or three
other ducking bystanders) It happened so quickly, I barely had time to duck
and pull the throttle down, to avoid hand grenading the engine.
Now picture one of those props doing the same thing.
Oh, and I also wonder what OSHA would think about that setup, nowadays.
(:-o)
Nah, that's a lie. I don't have to wonder! g
Jim in NC
Old April 25th 06, 08:06 PM posted to rec.aviation.rotorcraft,rec.aviation.piloting
"Steve R" wrote in message
You mean there's enough money out there to get you on that thing in the
first place??
Absolutely. It looks fun enough, and I'd be willing to take the risk,
given enough hazardous duty pay.
$5 isn't going to do it though. And payment would have to be guaranteed,
even in the event of my demise. Got a family to feed, ya' know.
A million bucks might be enough.
Pete
I'm glad you're able to place such a solid figure on the worth of your life!
I'm not sure I could do that. A million bucks isn't going to mean much to
me if I wind up in the consistancy of thin sliced bologna! ;-)
Good luck,
Steve R.
