On Sun, 23 Apr 2006 18:43:26 -0400, Roger
wrote: On 23 Apr 2006 02:18:53 -0700, wrote: Ernest, I agree with alot of what you said. The point of my OP was not to challenge what the best care of the engine is. I think we all agree that flying it an hour a week is what is called for, along with regular oil changes. What I has me concerned is that many times during the winter, it is difficult if not impossible to do this. In that Get a good engine block and cylinder head heater. Wrap up the entire cowl with plenty of good thermal blankets and use an engine heater to keep the oil dry. I should add that keeping the heater on all the time comes with some caveats. One being the whole engine has to get hot and in most climates where it's necessary to preheat the engine that means thoroughly wrapping up the front of the airplane from the firewall forward. The blankets I've cut go half way up the windshield and behind the cowl flaps. Some one asked about this and I can't find the post. I regularly check the engine by pulling the dip stick. If things aren't hot enough there will be moisture condensing under the top of the dipstick or oil filler cap. Everything on the engine gets hot enough that it's uncomfortable to put your hand on it. You can do so without getting burned, but if you are not expecting it, you will jerk your hand back away from the cylinders. Based on that I'd guess the temp is pretty close to 50C or about 122F (if I did the math right) That's not 180, but it's not getting combustion products put in at the same time either. Another caveat is; don't leave the thing set for more than a couple of weeks. The engine is hot enough the "cling" will quit clinging. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com situation, I think it is better to warm up the engine than just let it sit. The cam and lifter on Lycomings will tolerate no rust at all. Once you have even a small rust pit in the lifting face of the cam or lifter I'm afraid you are looking at a tear down in the not too distant future. Literally beats them to death in short order. And like I said, my oil analysis results show no water at all, zero. As for the engine making water, of course it does, and it goes right out the exhaust as you said. I don't think the engine stays very cold for any length of time once running. Those babies get hot, and quick, even in the winter. I doubt if they collect much if any water during start up. I also don't think the oil turns to an acid capable of dissolving the engine. I Again we disagree. If I don't use the engine heater the oil will be almost milky within the first five hours. Using the heater it's still clear to around the 20 hour mark. OTOH my engine has no oil filter so the oil changes come at 25 hours. In 25 hours the oil doesn't go down enough to hardly see on the dip stick, so it's using less than a pint in 25 hours and is almost at TBO. BTW it has a wet vacuum pump. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com could be wrong, as I haven't done the research, but then, I don't think anyone else has either. Some say they have, but they aren't showing it for us to see, at least not that I'm aware of. I realize that the 180 deg is probably meant as a guide, but they do state specifically that if you don't hit 180, the water won't evaporate. I think this is nonsense. The oil in a running engine is literally blown and slung around like a hurricane. It doesn't just sit at the bottom of the sump. And the volume of oil pumped is huge. 90 psi will do that. I think that there probably are pockets within the engine that trap water. The front of the hollow crank comes to mind, but I don't think they ever get purged of their water, even after hours of operation. Blue skies, Rusty |
caveats. One being the whole engine has to get hot and in most climates where it's necessary to preheat the engine that means thoroughly wrapping up the front of the airplane from the firewall forward. The blankets I've cut go half way up the windshield and behind the cowl flaps. The problem with keeping an engine too warm all the time: degraded rubber hoses, seals and gaskets. Rubber parts lose their lighter elements faster when hot and get hard; they shrink, crack and leak. They'll do it over time too, of course, but heat accelerates it. The same thing applies to aircraft interiors and radios when subjected to the heat of the sun. Nothing lasts forever. We don't want to think about that sometimes. Your airplane is aging whether it's flying or not, and you can only slow it as much as practicable. I would be more inclined to use dessicant plugs (with "Remove Before Flight" flags attached) on the engine breather, exhaust and intake. Cheaper than heating and easier on rubber. Dan |
On 28 Apr 2006 07:52:31 -0700, wrote:
I should add that keeping the heater on all the time comes with some caveats. One being the whole engine has to get hot and in most climates where it's necessary to preheat the engine that means thoroughly wrapping up the front of the airplane from the firewall forward. The blankets I've cut go half way up the windshield and behind the cowl flaps. The problem with keeping an engine too warm all the time: The Key here is the word "too". The Tanis heater doesn't keep the engine too hot. degraded rubber hoses, seals and gaskets. Rubber parts lose their lighter elements faster when hot and get hard; they shrink, crack and leak. They'll do it over time too, of course, but heat accelerates it. The same thing applies to aircraft interiors and radios when subjected to the heat of the sun. The entire plane including the interior gets a lot hotter out in the sun than the engine does from the heater. Nothing lasts forever. We don't want to think about that sometimes. Your airplane is aging whether it's flying or not, and you can only slow it as much as practicable. I would be more inclined to use dessicant plugs (with "Remove Before Flight" flags attached) on the engine breather, exhaust and intake. Cheaper than heating and easier on rubber. On many you can not get to the intake to put in a desiccant plug in a manner that would do any good. Just stuff a tennis ball in the exhaust(S). If you forget them it's no problem as they will be gone before the first cylinder fires. OTOH if they stick for some reason they'll be gone right after the first cylinder fires, but they may be more difficult to find. The place where desiccant plugs do the best is when they are put in place of spark plugs. OTOH they have to be replaced every two weeks or so. If the engine is going to set that long, I'd think it'd be better to make sure the oil is clean, pull the plugs and spray oil into the cylinders and then insert the plugs or desiccant plugs. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Dan |
Water in our oil, or just alot of hot air? | [email protected] | Piloting | 9 | April 24th 06 05:30 AM |
Water in our oil, or just alot of hot air? | [email protected] | Owning | 24 | April 24th 06 03:27 AM |
Induction System Water Problem | Mike Spera | Owning | 1 | January 30th 05 05:29 AM |
Questions regarding Air/Oil Separators | Doodybutch | Owning | 6 | April 20th 04 05:56 PM |
Water Cooled Jet Engines: a possibillity then and now? | The Enlightenment | Military Aviation | 3 | December 18th 03 09:41 AM |
