Water in our oil, or just alot of hot air?
Old April 24th 06, 05:47 AM posted to rec.aviation.homebuilt
Default Water in our oil, or just alot of hot air?
On Sun, 23 Apr 2006 19:40:10 -0400, "Morgans"
"Roger" wrote
We must live in different climates.
Here in Central Michigan it's not unusual to find the airplane
"dripping" wet with temperature changes.
I have an garage attached to the house. It's not unusual to find the
cars sweating with temperature and humidity changes. I had to work on
the garden tractor today and the engine is wet from the humidity and
temperature changes. (It's been 100% since last night and rained most
of the day.
I feel your pain! g
NC is like that, at times, also.
Winters are getting a bit warmer, (5 weeks shorter in the last 50
years according to the State of Michigan DNR) and more humidity. That
means we spend more of the year in the 30 to 50 degree range with high
humidity.
Want a good piece of advise? Insulate your garage, put up good insulated
garage doors, and with good seals installed. Run one 8" duct into the
It's already insulated with insulated doors, but I need to add the air
duct.
I'm glad you mentioned that as the duct ends within two feet of the
garage wall. All I need is to add a shutter/valve to the duct, cut a
hole through the 2 X 10 and install a register. It'd probably be a
lot better if I carried it up the wall and over to the center of the
garage, but being lazy I'll be lucky to get it into the garage. Great
idea though.
garage from your central heat and air. It makes a huge difference at not
all that much expense.
www.rogerhalstead.com
Old April 24th 06, 12:16 PM posted to rec.aviation.homebuilt
On Mon, 24 Apr 2006 00:47:38 -0400, Roger
duct.
idea though.
roger site the vent so that it ducts on to the floor and try for
coanda effect to take the blast into the centre area.
I'm sure it can work.
Stealth Pilot
Water in our oil, or just alot of hot air? [email protected] Piloting 9 April 24th 06 05:30 AM
Water in our oil, or just alot of hot air? [email protected] Owning 24 April 24th 06 03:27 AM
Induction System Water Problem Mike Spera Owning 1 January 30th 05 05:29 AM
Questions regarding Air/Oil Separators Doodybutch Owning 6 April 20th 04 05:56 PM
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 09:41 AM
