On Sun, 23 Apr 2006 22:45:06 -0400, "J.Kahn"
wrote: You don't really need to fly it once a week. Once a month will do as long as it gets an hour or so. an hour or two *after* the engine temperature is at the normal running temp range will see it right. white oil? fill it up with avgas and fly out the tank in one uninterrupted flight and it should be black again. my aircraft occasionally sits for longer than I want and I find on a long cross country that by the end of the second day's flying it is running like a well oiled sewing machine again. flying for shorter periods never seems to get the sewing machine effect where it runs noticeably sweeter. Stealth Pilot |
On Mon, 24 Apr 2006 19:25:08 +0800, Stealth Pilot
wrote: On Sun, 23 Apr 2006 22:45:06 -0400, "J.Kahn" wrote: You don't really need to fly it once a week. Once a month will do as long as it gets an hour or so. an hour or two *after* the engine temperature is at the normal running temp range will see it right. white oil? fill it up with avgas and fly out the tank in one uninterrupted flight and it should be black again. An hours flight will remove the water and I already use 100LL. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com my aircraft occasionally sits for longer than I want and I find on a long cross country that by the end of the second day's flying it is running like a well oiled sewing machine again. flying for shorter periods never seems to get the sewing machine effect where it runs noticeably sweeter. Stealth Pilot |
Water in our oil, or just alot of hot air? | [email protected] | Piloting | 9 | April 24th 06 05:30 AM |
Water in our oil, or just alot of hot air? | [email protected] | Owning | 24 | April 24th 06 03:27 AM |
Induction System Water Problem | Mike Spera | Owning | 1 | January 30th 05 05:29 AM |
Questions regarding Air/Oil Separators | Doodybutch | Owning | 6 | April 20th 04 05:56 PM |
Water Cooled Jet Engines: a possibillity then and now? | The Enlightenment | Military Aviation | 3 | December 18th 03 09:41 AM |
