P. Corbett wrote:
What is a sensible and safe FLOAT charge rate for a 14 V, 12 AH sealed lead acid battery? Thanks in advance, Paul The "classic" glider "gel cell" which is 12 v and 7Ah typically likes to see 13.8 volts if you're going to leave it on charge all the time. I've used constant voltage battery chargers set at 13.8 volts for 10 years and never had a battery issue in flight. Plug it in and forget it. |
Basic battery charging question | [email protected] | Soaring | 28 | April 10th 06 03:12 PM |
Battery Question | [email protected] | Soaring | 19 | September 15th 05 01:38 AM |
Mountain High EDS O2 system battery | Bill Daniels | Soaring | 20 | March 16th 05 03:18 AM |
Batteries, charger for Yaesu handheld - NiCad or NiMH? | David Herman | Owning | 10 | November 7th 04 04:30 PM |
Handheld battery question | RobsSanta | General Aviation | 8 | September 19th 04 03:07 PM |
