Because it would be much harder to get slowed down going down the
glideslope, trying to get below gear speed. "Steven P. McNicoll" wrote in message ink.net... "Chris Brooks" wrote in message ... Because I could descend to 4000 fast and then get slowed down. Why do you want to do that? |
![]() "Chris Brooks" wrote in message ... Because it would be much harder to get slowed down going down the glideslope, trying to get below gear speed. Well, why is that necessarily harder? Why do you want to go so slow so far out? Even if you do, why is it harder to slow down at 5000 than it is at 4000? |
At 5000 I was going to intercept the GS very shortly. I was going too fast
to put the gear down. Instead of incercepting the glideslope at 5,000 and following it down 700 feet a minute where it would be very difficult to get under gear speed, you can haul down to 4,000 feet (at 1000 - 1500fpm), then start slowing down. Then when you hit HAIGS, you step down to the next fix and then configure the airplane for GS intercept. It was in a C402 which can be difficult to slow down, without shock cooling the engines. if you intercept the glideslope high, it would be tough to get within gear speed without bringing the engines way back (shock cooling). "Steven P. McNicoll" wrote in message ink.net... "Chris Brooks" wrote in message ... Because it would be much harder to get slowed down going down the glideslope, trying to get below gear speed. Well, why is that necessarily harder? Why do you want to go so slow so far out? Even if you do, why is it harder to slow down at 5000 than it is at 4000? |
A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 05:07 AM |
Question: DP altitude vs MCA/MEA | Doug Easton | Instrument Flight Rules | 7 | April 7th 04 03:29 AM |
Question | Charles S | Home Built | 4 | April 5th 04 09:10 PM |
Tecumseh Engine Mounting Question | jlauer | Home Built | 7 | November 16th 03 01:51 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
