Water in our oil, or just alot of hot air?
Old April 24th 06, 09:37 PM posted to rec.aviation.homebuilt
Default Water in our oil, or just alot of hot air?
Admittedly, there are direct spray modifications available for the
Lycoming
cam lobes--according to a bonafide Lycoming Bigot in my chapter
We're buying three Lyc Factory overhauls this spring (O-320) and the
dealer tells me that Lycoming has come up with a roller tappet and cam
to match. The case is different, to make room for the extra machinery.
It's an option right now, apparently. I imagine they'll try to convert
the fleet. The roller tappet is likely in response to scuffing issues.
We haven't had any problem with scuff for years, since we started using
an oil with the additive Lycoming recommends (Aeroshell 15W50).
Dan
I've thought for some time that roller tappets would be the real solution,
and I am glad to hear that they will be offered for the O-320.
If you're buying three, your equipment probably dosn't have excessive
periods of inactivity. It's also good to hear that the recommended oil
additive has resolved any residual scuffing problems up until now.
Peter
Old April 24th 06, 11:51 PM posted to rec.aviation.homebuilt
Peter
They fly a lot, and that's what makes them last well. But we
still find water in the rocker covers after just a runup of about 10
minutes before inspection, even in summer weather. It's not there if
the airplane comes in after a flight, unless the weather was really
cold. We'll also often see water droplets on the oil dipstick.
On the other hand, in my old A-65 in my Jodel, I see corrosion
simply because it doesn't get flown much and when it does it's for
rather short flights. Too busy working on airplanes or with students to
find much time to play.
Dan
Water in our oil, or just alot of hot air? [email protected] Piloting 9 April 24th 06 05:30 AM
Water in our oil, or just alot of hot air? [email protected] Owning 24 April 24th 06 03:27 AM
Induction System Water Problem Mike Spera Owning 1 January 30th 05 05:29 AM
Questions regarding Air/Oil Separators Doodybutch Owning 6 April 20th 04 05:56 PM
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 09:41 AM
