An amphibian that sank?
Old April 24th 06, 03:05 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Default An amphibian that sank?
The aircraft could have been deliberately sunk for training. Or, it
might have hit debris in the water or a submerged object and received a
whole punched through the fuselage. Lastly, water pumps might have
failed causing it to sink gradually between pilot visits.
That last was really what I was wondering. If it didn't get much use, a few
loose rivets could be enough.
Peter
  #32
Old April 24th 06, 03:09 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
"Bob Moore" wrote in message
. 121...
Roy Smith wrote
Barf. Never use "MacGregor" and "sailboat" in the same sentence.
They are the most butt-ugly things in the universe.
But were not always so. I owned a 1976 MacGregor "Venture 25" that
was a very attractive small boat very similiar in appearance to the
O'Days and Catalinas of the same size.
Bob Moore
They were indeed pretty boats, although I never saw the inside of one.
Peter
  #33
Old April 24th 06, 03:38 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
"Richard Lamb" wrote in message
Peter Dohm wrote:
"Roy Smith" wrote in message
"Peter Dohm" wrote:
Some of the small sail boats also have foam filled compartments with
same effect. The name MacGreggor comes to mind from years ago, and
there
are probably others by now.
They
are
They actually did have a replica of a 19th century pilot boat that I
thought
was sort of neat, if less than practical, and commercially it was a
dismal
failure. But I really don't like most of their competitors boats very
much
either.
Peter
That must have been the 23 foot. Cute little ship.
Right down to the bow sprit.
I've been looking at a Catalina Capri 18.
Can't decide if it's too big, or too small, or just right...
Richard
You're right, it was the 23 foot. At the time it was a standard catalog
item, although I don't recall ever physically touring one. The feature that
I must liked, besides the outward appearance, was the interior layout.
Rather than trying to advertise sleeping 5 or even 6 people, it had a nicely
arranged forward cabin for two and either one or two bunks mid ship--I've
forgotten the number; but in they old days, they would have been available
to the crew while the paying passengers used the captain's cabin.
The Capri 18 may very well be just right. It's big enough to go belowdecks
for a nap, or even overnight, but small enough to be easily handled and
trailered.
One caveat regarding my nautical advice: Not much experience, and a lot of
that was in Sunfish. OTOH, if one of those old 23 foot MacGreggors should
come my way at about the right time...
Peter
  #34
Old April 24th 06, 04:56 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Jim Macklin wrote:
A better solution
is to fill the compartments with ping-pong balls. They
displace water, don't weigh too much and can be removed for
inspection and corrosion control.
Didn't the "Myth Busters" sink a boat and try to float it again by
filling it with ping-pong balls? If I remember right something on the
boat broke, and all the ping-pong balls spilled out.
Chris W
KE5GIX
Gift Giving Made Easy
Get the gifts you want &
give the gifts they want
One stop wish list for any gift,
from anywhere, for any occasion!
http://thewishzone.com
  #35
Old April 24th 06, 04:58 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Chris W wrote:
Jim Macklin wrote:
A better solution is to fill the compartments with ping-pong balls.
They displace water, don't weigh too much and can be removed for
They did that experiment on a sailboat they had sunk and it did in fact
bring the sailboat back to the surface.
  #36
Old April 24th 06, 05:40 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
"Newps" wrote in message
Chris W wrote:
Jim Macklin wrote:
A better solution is to fill the compartments with ping-pong balls. They
displace water, don't weigh too much and can be removed for inspection
Well I remember from my younger days when canoe swamps not to worry about
it. We did a test of our own back then. We swamped it so the canoe was
completely filled with water, but upright. Then we started sending people
out there to hang on the side rail and use the canoe to keep their heads out
of the water. We wanted to know how many people it would take to send it to
the bottom, but we never found out. We ran out of space on the side rails
for more people to grab.
Now I strongly suspect that it would difficult if not impossible to do the
same thing with an anphib. They are designed to fly not swamp.
  #37
Old April 24th 06, 07:53 PM posted to rec.aviation.piloting
Inland lakes mostly, but it could handle coasting in reasonable weather.
It's just too hot and humid at sea level...
You need one of the diesel powered air-conditioners...
  #38
Old April 24th 06, 11:24 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
"Chris W" wrote
Didn't the "Myth Busters" sink a boat and try to float it again by filling
it with ping-pong balls? If I remember right something on the boat broke,
Yep, a hatch gave way, but they screwed a piece of plywood on it, and then
brought to the surface.
Jim in NC
  #39
Old April 25th 06, 01:06 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Flyingmonk wrote:
http://www.divingservices.net/aircraft.jpg
http://www.divingservices.net/9bcess2.jpg
Anyone have the story behind this? Strange that a plane designed to
float, sank!
The Monk
So was the Titanic! ;-)
  #40
Old April 25th 06, 07:39 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
link.net...
"Flyingmonk" wrote in message
float, sank!
The Monk
I could be wrong, but wasn't the Titanic designed to float?
DH
As I recall it even had lots of watertight compartments designed so that you
could flood several of them and the Titanic would still float. Unsinkable,
they called it. After it sank, the Unsinkable title was transferred to
Molly Brown of Denver. :-)
Highflyer
Highflight Aviation Services
Pinckneyville Airport ( PJY )
Amphibian VTOL? Flyingmonk Piloting 6 January 6th 06 12:18 AM
Amphibian Aviat Husky Doug Aviation Marketplace 0 November 22nd 04 06:03 AM
Adventure Air Amphibian accident Ed Baker Home Built 3 November 12th 04 01:46 PM
New amphibian aircraft Sten-Anders Fellman Products 0 August 28th 04 11:47 PM
Amphibian down on Mt Kearsarge [email protected] Piloting 2 July 7th 04 11:32 AM
