"Will" wrote:
It's nice that a certified instrument flags an unsafe condition. I would still like to know the current level of GPS accuracy on a certified instrument, for many reasons: * It helps to educate me about GPS and conditions in my immediate surroundings that might affect accuracy of the technology. * It helps to alert me about possibly deteriorating conditions, before I get into a situation where I needed to rely on the instrument and suddenly I cannot. A handheld GPS used by a hiker in the woods is working under completely different environmental conditions than one on an airplane. The biggest reason for a hiker's GPS to get poor signal is because of nearby terrain or overhead foliage blocking line of site to the sky. By the time an airplane's view of the sky is blocked by overhead foliage, they've probably got bigger problems than not having a good GPS signal. |
"Roy Smith" wrote in message
... A handheld GPS used by a hiker in the woods is working under completely different environmental conditions than one on an airplane. The biggest reason for a hiker's GPS to get poor signal is because of nearby terrain or overhead foliage blocking line of site to the sky. By the time an airplane's view of the sky is blocked by overhead foliage, they've probably got bigger problems than not having a good GPS signal. For an FAA-approved device, properly installed, I think you are right probably 99% of the time. Of course even then you could imagine cases like what happens if the GPS antenna starts to slowly go bad? You don't want to learn about that when it reaches a critical failure point in the final part of an approach. Better to see the accuracy start out at 20 ft accuracy and slip over time to 50 ft, 80 ft, 100 ft, etc. Over many flights even an inobservant person might catch the deterioration and do something about it when there is time. For a non-FAA approved device, I think you are wrong. The problem here is that the GPS software has no way to guarantee the integrity of the satellite antenna, and very importantly it cannot guarantee the integrity of the antenna's placement within the cockpit. If the user accidentally selects XTrac mode without understanding the implications of that, places the antenna out of view of most satellites within the cockpit, etc, the software happily displays an aircraft position. And it never tells you that your current position is only accurate to 10,000 ft horizontal! The point is that in a non-approved device, the GPS software creates an illusion that you are on a 2D map position, at a spacial coordinate, but most of this software gives you no immediate way to determine if that reading is accurate to 10 ft or 10K ft. Knowing in advance that you are accurate to only 10K ft would probably give most pilots a reason to investigate why, maybe resulting in a better position for the antenna, for example. Maybe the user would find out that they had accidentally left the unit in XTrac mode and they need to switch over to a more accurate mode. Better to make these discoveries and tinker with such things in a calm environment. You don't want to make the discovery that the "backup" GPS display is worthless on the day you lose all your primary instruments in IFR conditions. I just don't understand the issue about pilot overload. I'm asking for two integers, and you don't need to look at them ever if you don't want to. -- Will |
says... I just don't understand the issue about pilot overload. I'm asking for two integers, and you don't need to look at them ever if you don't want to. Will, I think you should look at this picture : http://www.airliners.net/open.file?id=0286741 Then write back and tell us you really think we need some more numbers there, to give us redundant information. The 430's in the picture already have RAIM, and will warn the pilot if the information is below standard - Does this guy look like he's starved for more numbers to stare at? GF |
Greg Farris wrote:
Then write back and tell us you really think we need some more numbers there, to give us redundant information. The 430's in the picture already have RAIM, and will warn the pilot if the information is below standard - Does this guy look like he's starved for more numbers to stare at? GF I suspect he too busy worrying about what to do it an engine fails in that underpowered twin. |
In article Ato4g.174429$bm6.92343@fed1read04, says...
I suspect he too busy worrying about what to do it an engine fails in that underpowered twin. I'll let Mike Rappoport field that one, if he's with us!! |
Garmin backing away from additional GDL-69 features for 430/530 products? | Andrew Gideon | Owning | 2 | September 9th 05 11:36 PM |
Inexpensive Garmin 430/530 question | vlado | Owning | 2 | May 19th 05 03:21 AM |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
WAAS and Garmin 430/530 | DoodyButch | Owning | 23 | October 13th 03 04:06 AM |
Garmin 430/530 Questions | Steve Coleman | Instrument Flight Rules | 16 | August 28th 03 09:04 PM |
